11-22-2003, 10:38 PM | #1 |
Distributor hold down
Can you use the same hold down clamp for a hei distributor from a points distributor? The one I am using does not lock it down completely.
Thanks Last edited by skokie; 11-22-2003 at 10:41 PM. |
11-22-2003, 10:39 PM | #2 |
SAME......SAME ONE
11-22-2003, 10:42 PM | #3 |
Then I must be doing something wrong. Do you need to lift it any higher on the distributor?
11-22-2003, 10:44 PM | #4 |
Your clamp might be bent straight. I suggest going to auto parts store and buy a 5.00 chrome one.
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
11-22-2003, 10:45 PM | #5 |
is the flange on the dist. shaft flush with the engine...????
setted all the way in??? |
11-23-2003, 02:28 AM | #6 |
Yep its all the way in. It looks like this dist doesnt have as thick as a circle around it as the points one did. That may be why.
11-23-2003, 02:38 AM | #7 |
flip your hold down over
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
11-23-2003, 03:12 AM | #8 |
Don't say "Oops!", Doctor
...and make sure the bolt isn't bottoming out.
'Mutt 1968 CST LWB: R.I.P. 1967 Chevelle: TPI 454 beast 1967 C10 SWB: Claimed when Bumpster didn't put it on his list |
11-23-2003, 03:15 AM | #9 |
I will try flipping it over tomorrow. Maybe that will work.
Thanks |
