01-08-2019, 01:13 AM | #1 |
Spindle & coil install question
I'm working on a C-10. The control arms are original, the spindles drop 2.5", the coil springs are the original height, and the rest is Moog suspension.
I can't lift the truck, there's no weight on the frame. I could wait for the engine, but I'd like to try it with this interior compressor I picked up, and finish the suspension already. My question may be too obvious, but I'll ask. It strikes me I should torque the ball joints onto the spindle and then release the coil spring. Any reason why you'd want to leave some play, and finish torque after the coil spring is released? Thank you......... Finished the control arms today.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
01-08-2019, 10:05 AM | #2 |
Re: Spindle & coil install question
I dont see why you cant tighten things up then release the tension.. as for the removen the jack from under the a arm, I'd use a ratchet strap hooked to the frame and the jack in order to compress the spring.. just my 2 cents
01-08-2019, 10:05 AM | #3 | |
for a balljoint it wouldn't hurt either way as long as the boot isn't twisted up. fwiw i tightened thousands of balljoints on a lift on cars over the years working at a dealership. |
