01-08-2019, 02:27 PM | #1 |
Help with a 60
Hey guys, im about to start helping my friend sort out his 60. its lowered in the front with the wrong rear end. What do you recommend for a disk brake upgrade/suspension package power brakes everything? Ill get the right width rear end in it as well.
Im assuming this is the torsion bar truck. Can it be upgraded to coil or coil over easily?
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
01-10-2019, 02:01 AM | #2 | |
Re: Help with a 60
If you want to get rid of torsion bar suspension you can swap out a newer clip if you do a search you will find some nice DIY posts. You will need to get a new master cylinder and booster ( if you want power brakes) . Make sure you get the correct one disc/drum or disc/disc If you have a stick with the hydraulic clutch Captain Fab has a nice kit that will let you keep it and mount your master cylinder. You need a proportioning valve and will have to make new brake lines. Check the FAQ section there is a ton of info on disc swaps. Have fun
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
01-10-2019, 12:14 PM | #3 |
Re: Help with a 60
Thanks for the reply. This is the plan right here. Stick with torsions, dropped spindle disc brake kit, booster/master, all new ball joints, steering, etc...
04-10-2019, 05:05 PM | #4 |
Re: Help with a 60
You didn't tell me how much $$$$$$$$$$$$$$$$$$$$$$$$$$$ the ball joints and control arm shafts would be!
04-14-2019, 10:35 PM | #5 |
Re: Help with a 60
They have gone up in price !!!
