Old 01-08-2019, 05:58 PM   #1
Chevymann66
Chevymann66's Avatar
84 C10 Duel Tank LS?
Is there anyway to run duel tanks with an LS swap? Was thinking of running a external fuel pump after the fuel tank selector valve & running the supply/return line to the valve. I would use AN fittings to the rails, but the valve is plastic & could only use rubber lines. Would this work?
https://www.summitracing.com/parts/fif-40005
I have an 1984 C10 with duel 16 gallon tanks & with 3 port sending unit.
Donor truck is an 2000 5.3 Silverado.
---1964 C-10 SBW -Short Bed-
---1966 C-10--350 V8-4 Spd-BBW-Short Bed- SOLD!
---1964 C-10 :283 V8 -BBW Long Bed
Chevymann66 is offline   Reply With Quote
Old 01-08-2019, 06:10 PM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: 84 C10 Duel Tank LS?
I know it's been done
I didnt research the pump you have listed but you'll need 55-60 or so lbs of fuel pressure
The suction side is low pressure...I used fuel hose and clamps
If the return is unrestricted it can be low pressure...not sure how it would work through the sell tor valve
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
