01-10-2019, 11:57 PM | #1 |
filler tube relocation - wood bed
So I just purchased a rear gas tank from Classic Industries as it was on sale. It doesn't appear to come with a filler tube, although maybe I'm wrong.
I plan on mounting the filler tube/opening in the bed floor as it's a stepside. Truck is a 70 C10, SWB with a wood floor. I'd like a fuel cap that is somewhat flush with the wood floor. Anyone have any recommendations on where to get a good one? Pics would be cool if you have any. I've run a bunch of searches and didn't seem to find what I'm looking for, hence the new post. Thanks in advance. |
01-11-2019, 12:02 AM | #2 |
Re: filler tube relocation - wood bed
Here's a neat site that will have everything you need. I also have a 70 swb stepper and I have a similar plan: post some pics of yours.
http://www.tanksinc.com/index.cfm
DAVE Edmonton, Alberta 1959 Apache 1967 K20 1968 C20 1970 C10 1972 GMC 2500 1981 C10 |
01-11-2019, 12:57 AM | #3 |
Man I just hate it when I see a gas cap in the floor bed ,how do you keep from spilling gas on that pretty floor ? Then you cant get gas if you got something in the back that covers it up. Just My opinion don't mean to ruffle feathers but heres a little trick I used. And easy to do
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
01-11-2019, 01:12 AM | #4 |
Mine is a step side.
01-11-2019, 07:55 AM | #5 |
You are correct. They do not come with a filler tube.
Did you buy the top fill, or side fill tank? Top fill you have to go through the bed, side fill you can do what kaycee above did. For top fill most people use a boat/marine/motorcycle style filler cap. Here is a great site to get ideas. https://www.fillernecksupply.com/ Mine is the side fill, same as kaycee's. I used a mid 90's Chevy S10 setup including the door hinge assembly, plastic filler tube pocket, and the top 6 1/2" of the filler tube. Bought for $15 at a junk yard. The rest I cobbled together from the auto parts store, and Lowes. The cap is a Permacap which has a trap door top just like the new cars and trucks. I did have to notch the left rear frame rail, trim the bottom of the left bedside(red arrow), and trim the bed support sill that runs over the tank as the tank top is above the frame when installed. I also converted to LED side marker lights so there is no issue with the light being so close to the filler. It fills pretty good, but you have to go at about half speed on the nozzle flow, or it backs up. Here are some pics of the install. There are tons of posts on this forum, just search for rear tank conversion and you will find plenty to look at. |
01-11-2019, 07:55 AM | #6 |
As a step side, you have more room in the fender to run the tubing up to the side marker light. Do a search on here and there’s some good info on that.
Edit: Zeroman beat me to it
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
01-11-2019, 01:50 PM | #7 |
Ditto what zeroman said Great minds think alike
01-11-2019, 02:06 PM | #8 |
Thanks guys. I bought the center fill, so I'll probably just stick with a bed mount. Thanks for the info.
