Old 01-11-2019, 12:19 AM   #1
65btk
Rochester 1 barrel carb help
Start off by saying I've been a long time lurker on the site while I slowly buils my 65 c10. I have been doing a budget build on it and refreshed and painted the Inline 6 230. Well I went to rebuild the 1 barrel rochester type b carburator and broke the power piston tube. I have looked around and can find my exact one any were. https://www.carburetor-parts.com/Roc...n-_p_3654.html . Tryed that website and they do not sale used parts no more. Can some point me in the right direction on where I can get this part?
65btk is offline   Reply With Quote
Old 01-11-2019, 12:29 AM   #2
kazoocruiser
Re: Rochester 1 barrel carb help
https://www.carbs.us
kazoocruiser is offline   Reply With Quote
Old 01-11-2019, 08:57 AM   #3
The Rocknrod
Moderator
The Rocknrod's Avatar
All I have is info for 2 barrels that 'someone' might need - https://www.dropbox.com/s/kl61oa8v65...arrel.pdf?dl=0
Old 01-11-2019, 10:31 AM   #4
vin63
It's Better With Nitro
vin63's Avatar
Here are a couple of other resources I've used in the past for various projects...
https://quadrajetparts.com/rochester-1bbl-c-241.html
http://www.carburetion.com/r1.asp
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 01-11-2019, 07:59 PM   #5
jdl71
jdl71's Avatar
Can you post a pic of what exactly you need? The power piston itself?
Psalm 23
64 C10
66 K20
jdl71 is offline   Reply With Quote
Old 01-11-2019, 09:03 PM   #6
65btk
Ive tryed a few of those sites but will call the ones I have not on monday.
Old 01-11-2019, 09:08 PM   #7
65btk
Just need to get carb rebuilt and hei distributor and I will finally be on the rode.
Old 01-11-2019, 10:06 PM   #8
63frankintruck
Those one barrells are junk. Try doing a google search and convert yours to a 2 barrell 2cg carb (they are supposed to give you much better drivability and gas mileage)
I'm going to try this route on my dads 50 Chevy
63frankintruck is offline   Reply With Quote
Old 01-11-2019, 11:55 PM   #9
Cris
Try these guys:
https://daytonaparts.com/index.html
Regards, Cris
Cris is offline   Reply With Quote
Old 01-12-2019, 09:29 AM   #10
jdl71
jdl71's Avatar
I have some parts carbs let me see what I have. That’s a Rochester B, correct?
Psalm 23
64 C10
66 K20
Old 01-12-2019, 05:41 PM   #11
jdl71
jdl71's Avatar
PM me your address and I will put it in the mail Monday
Psalm 23
64 C10
66 K20
Old 01-12-2019, 07:17 PM   #12
65btk
2 barrel sounds nice but would like the get this running cheap as possible right now. I need to get it on the road so I get intrested in it agian. Thanks for all the sources. Pm you jdl71.
Old 01-13-2019, 11:47 AM   #13
TJ's Chevy
TJ's Chevy's Avatar
I'll second popping a 2 barrel on. All you need is an adapter and either a Holley 500 or Weber 32/36. Throttle linkage mod and you are on the road. Once the Weber was tuned properly folks were getting pretty dang good mileage out of the 230 and 250. Food for future thought.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 01-13-2019, 02:27 PM   #14
65btk
I think once she is running and driving it will get me motivated to look in to that 2 barrel option and other upgrades.
Old 01-13-2019, 04:03 PM   #15
63frankintruck
I picked up a two barrel Rochester 2cg the other day for 20 bucks off craigslist and bought a kit for it for $18 and was going to make an adapter plate to go from 1 barrel- 2 , but found an adapter for $45 and went ahead and did that. I’ll try to keep You posted as to how it works out.
