Old 11-23-2003, 01:48 AM   #1
mattopia
new radio question
I want to put in a new style radio in my truck (81 SWB) the last owner apparently had done it because the metal part of the dash is cut but the bezel is not. What have the rest of you done? What is the best way to brace up a radio for the bumpy road ahead? Thanks
mattopia is offline   Reply With Quote
Old 11-23-2003, 03:01 AM   #2
Russell
Professional Grade
Russell's Avatar
Take a rotozip or sawzall or something similar and cut it out after carefully measuring your hole, you don't wanna mess up and make an unsightly mess. Take it nice and slow so you don't crack the bezel. To brace the stereo, you'll want to use some steel strapping and either wrap it around the stereo and bolt it up to something solid above the stereo, or you'll want to bolt the strapping to the back of your stereo then bolt it up above. Be very very very careful if you are planning on installing your own bolting point on the back of the stereo, they pack those little units FULL of delicate electronics. I would very highly recommend that you do not take to your headunit with a drill
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 11-23-2003, 03:41 AM   #3
crackajacka
Stylin
crackajacka's Avatar
what brand some have screw holes on the side where u can bolt them to a brace.
Ive been traveling for some time, with my fishin pole and my bottle of shyne.
Most Girls like finished products and just dont understand what a good addiction does for you
http://www.paulwall.us/
crackajacka is offline   Reply With Quote
Old 11-23-2003, 01:45 PM   #4
mattopia
jvc
Old 11-23-2003, 06:08 PM   #5
crackajacka
Stylin
i dont know about jvc but i think it would have some sort of mounting holes on the side
Old 11-25-2003, 02:30 AM   #6
stan79chevy
stan79chevy's Avatar
i used that plumbers tape stuff
it has worked nice so far
79 chevy k20 350/350/205/D44/14bFF
4.56 gears rock
LWB pimer black
01 S-10 ZR2 extended cab
4.3/4L60E/233
3.73 gear 31" DICK CEPEK CRUSHERS
stan79chevy is offline   Reply With Quote
