landarts
![]() Join Date: May 2005
kick panel vent pins and springs
I am trying to knock a few more items off of the punch list with the 72 Fixrupr build. I tore down the fresh air vents a few years ago and sand blasted, painted and replaced worn out foam inserts. I misplaced the pins and springs that help hold them in the kick panels. Is there any place out there that sells them? I have looked and just not able to find them. First image is what I am looking for. Second are mine ready to go back together.
Super Cheyenne aka the "Devil Cowboy" 71 K20 Idaho Edition 69 K10 from the Field 68 Second Chance Fix and Sale 72 GMC 3/4 ton 4x4 K2500 The "Fixrupr" build thread 72 Cheyenne 1/2 ton " FIXRUPR " - daily driver 67 C20 all original paint 71 K20 Custom 4x4 (Idaho Edition) 72 K20 GMC Super Custom 4x4 72 K20 Custom Deluxe 4x4 69 K10 Custom package 4x4 (69 K10 from the field) 72 K10 Custom 71 K10 Custom 72 K20 Custom Deluxe 4x4 72 K20 Crew Cab Project 71 GMC Jimmy CST 72 Blazer 70 Blazer |
landarts
Re: kick panel vent pins and springs
Never mind I found a way to make it work with long screw, cut the head off and threading it up and down raise and lowers so you can remove or install. After the final assembly I will post a picture so if anyone else gets into need for the same.
Old member
Junkyards would be my suggestion but it sounds like you figured it out.
You may could use a couple of old ink pen springs and some small rods to. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
