01-12-2019, 07:10 PM | #1 |
Hotchkis Stage 1 TVS or Ridetech Street Grip
I'm considering both of these kits kits for my 70 C10. I've looked around and don't see much information on either kit. Do any of you have any experience with them? I don't intend on racing this truck but I want it to handle well. I'm leaning toward the Hotchkis kit with 2" drop springs and drop spindles. Any thoughts would be appreciated. Listed below are the links to each kit:
https://www.hotchkis.net/product/tvs...k=&yr=&md=&sm= https://www.ridetech.com/products/su...etgrip-system/ |
01-13-2019, 11:46 AM | #2 |
Re: Hotchkis Stage 1 TVS or Ridetech Street Grip
I used to own a Dakota R/T. I realize you are asking about a your C-10. I installed a Hotchkis kit on that truck. It was a nice kit, however, it was a pretty stiff ride. It was stiff enough that my wife didn't really like riding in it. I don't know if that's a deciding factor for you or not, but something else to think about. Everything fit fine and seemed to be well engineered.
You might want to talk to one of the Ride Tech guys. There's one on here, John I think. Pick his brain a bit and see what he has to say. |
01-14-2019, 09:49 AM | #3 |
Of the two mentioned, I'd personally go with the Ridetech system, since it comes with the drop spindles and control arm parts.
However, you didn't specify if your truck already had disc brakes, etc., so I'm assuming you still have drum brakes, so you still need to buy rotors, calipers, brake lines and bearings. Next, you'll probably want to upgrade ball joints while rebuilding the stock control arms and replace the worn out pitman arm, idler arm and inner/outer tie rods. Also, you'll still be using the stock power steering box(if equipped), which may be ok, but the stock pre-73 boxes are wide ratio boxes, so a quick ratio box or 73-up variable ratio box would be a good upgrade. By the time you add all that up, you won't be far off from a whole suspension kit like this. https://totalcostinvolved.com/produc...o-touring-ifs/
01-18-2019, 11:43 PM | #4 |
I guess neither of these kits are used much on these trucks. I see that the ECE 4/6 drop kit is highly recommend. Does it noticibly improve handling? Would the ECE kit with front and rear sway bars improve the cornering? Again, I’m not looking to race this truck but I would like it to handle well.
01-19-2019, 08:58 AM | #5 |
the hotchkis TVS system is more geared for handling , So you will most likly feel a stiffer ride , I am about to pull the trigger on the ridetech street grip system for my daily driver for a few reasons, the first is ridetech claims increased handling with maintaning a comfortable ride , the other factor for me is they also claim no payload loss with there system. and I do like the drop/stance that the c/10s ive seen witht he street grip installed, and if you already have a disc brake conversion you can deducted the price of those parts from the street grip system.
01-20-2019, 09:58 PM | #6 | |
motor exploder
Their sway bars are great and I liked their springs too, but their rear springs were a little too stiff for my combination @ 380#/in. I believe thats the rate of the factory springs, but I have not personally tested a factory spring to determine that - if anyone knows for sure, please post it up. I'm running a big block with over 700#/ft of torque, and the stiff springs just blew the tires off at any speed. But, you could sling it into a turn (and I don't cut my truck ANY slack) and the front tires planted with no problem. It was just that I couldn't power out of turn with much throttle. I had a set of rear springs custom wound with a lower rate and the same 6" drop, but have yet to drive the truck since I installed them. They may not be any better, but I had to try something else to try and get the rear tires to hook. The quality of the Hotchkis stuff is very nice, and I'm sure the RideTech stuff is very nice as well. Please keep us posted on whatever you decide and let us know how it drives.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! |
01-20-2019, 11:10 PM | #7 | |
My kit came in last week but I blew my knee out so I haven't had a chance to swing by and pick it up. If all goes well I will be starting on it next weekend.
Ryan 1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840 1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628 1967/71 Blue SWB C10..SOLD 1977 SWB K10..my grandpa's.....never should have sold |
01-21-2019, 02:00 PM | #8 | |
That said, an ECE 4/6 drop kit with proper shocks and good sway bars will handle quite well for spirited back road driving, but will have limitations in a true "performance handling" situation like autocross. In fact, from what I've witnessed, and from one-on-one conversations with Bret Voelkel, the Ridetech StreetGrip and the Hotchkis kit will have the same limitations due to the basic geometry of the stock control arms and steering box. The StreetGrip system is designed for giving the popular 4/6 drop that many desire, but with improved ride quality using dual rated springs and upgraded delrin bushings and control arm hardware for increased suspension stability(no mushy rubber bushings). It is NOT designed to transform a truck to an autocross beast. That's what they make the coilover set for.
01-21-2019, 02:19 PM | #9 |
Thanks for all the responses. For now I'm going to use the ECE 4/6 drop kit. I'll probably add a front sway bar and hopefully I will like the way it handles.
01-21-2019, 02:23 PM | #10 |
After reading some more, I noticed you have THIS THREAD going also. As I mentioned before, keep track of your costs, and add everything up before making any decisions. By the time you buy the ECE brake kit, and the Ridetech kit, you're already in $3300+ and haven't even bought ball joints or steering linkage rebuild parts.
01-21-2019, 06:05 PM | #11 |
motor exploder
If you do NOT add a sway bar you might be disappointed with the handling after spending the money to lower your truck. Just my $.02. A quality lowering kit (like ECE), good shocks and a front sway bar goes a long way on these trucks for good street handling. It will still feel like an old truck, but it won't be as scary as a stock height truck with wasted shocks, old springs, no sway bar and drum brakes!
01-22-2019, 09:31 AM | #12 | ||
