Old 01-13-2019, 01:04 AM   #1
KMC3420
KMC3420's Avatar
Instrument cluster swap
I have a 79 K10 that has the idiot lights. I have purchased 77-79 gauge cluster that has the actual gauges. Does anybody know if the senders are the same regardless of idiot lights or actual gauges? Also, is the pin out the same or should wires be changed to make the swap work. Thanks.
Keagan
68 SWB C-10 original 350 A/C 503 Mean Green
KMC3420 is offline   Reply With Quote
Old 01-13-2019, 08:01 AM   #2
Dead Parrot
Re: Instrument cluster swap
Senders ARE different. Idiot light senders are basically on-off switches. Gauge senders are variable resistors. There are different gauge senders depending on max sweep on oil pressure and year of temp gauge. Chances are high that you have some cluster connector pin moving/adding to do.
If you are swapping clusters, good time to swap to LED back lights.
Several threads on the forum on matching senders to gauge and cluster pinouts.
Dead Parrot is offline   Reply With Quote
Old 01-13-2019, 01:16 PM   #3
KMC3420
KMC3420's Avatar
Thanks DP. I will see what threads I can find. I am prepared to buy all new senders, if I can find what senders are needed. Just to make the swap smoother. I did see where LED’s were swapped in to most clusters while having them out. I will likely do the same.
Keagan
Old 01-13-2019, 02:49 PM   #4
Double check the wiring pin-outs on the harness also. I believe the non-gauge cluster puts a couple wires in different positions.
Palf70Step is online now   Reply With Quote
Old 01-13-2019, 06:56 PM   #5
kipps
The clusters are easy enough to check. Put both side-by-side, and visually compare the printed circuit boards. It's a good exercise anyway, just to acquaint yourself with the way the thing works.
kipps is offline   Reply With Quote
Old 01-14-2019, 01:23 PM   #6
KMC3420
KMC3420's Avatar
Thanks guys, I did clean up the new cluster and will pull both of them and compare side by side. I am sure I will have questions on the pin outs when the time comes.
Keagan
Old 01-14-2019, 02:14 PM   #7
hatzie
Moderator
hatzie's Avatar
There are pinout sheets in the 73-87 FAQ
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
