Old 01-13-2019, 02:06 PM   #1
bmchevy1979
bmchevy1979's Avatar
K20 Caliper Brackets
Hello everyone. I was wondering if anyone knew the measurements or could take some to tell k20 caliper brackets from a k10 set. I'm doing a 8 lug swap onto a truck and I have the spindles, hubs and rotors. But I'm not sure if I have the right caliper brackets i have 2 sets that measure the same and the truck is a driver so I don't want to strip it down and things not work.
<Brandon>
1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works.
1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15
81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in
1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096
1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195
bmchevy1979 is offline   Reply With Quote
Old 01-20-2019, 02:53 AM   #2
bmchevy1979
Re: K20 Caliper Brackets
Anyone?
<Brandon>
Old 01-20-2019, 03:49 AM   #3
kwmech
I can tell you, you'll more than likely just need a tape measure to tell the difference. The diameter of the 3/4 ton supports are larger due to the extra diameter of the 3/4 ton rotor.
Old 01-21-2019, 07:09 PM   #4
bmchevy1979
Yes I was hoping someone had some known 3/4 ton brackets they could measure I'm not certain which ones I have. I didn't want to pull another truck apart just to take measurements. I haven't gotten rotors yet either so I can't put the setup together off the axle to see if the calipers will bolt up and clear
<Brandon>
