Old 11-23-2003, 03:12 AM   #1
ucmydust68
fuel
would a 3 gallon tank work for???
ok i am finishing my chassis for my 72 short box and i have a 3 gallon tank for my rear air ride but now i want baggs in the front also, would this three gallon tank be ok to do all four?
ucmydust68 is offline   Reply With Quote
Old 11-23-2003, 01:46 PM   #2
grnddwn
belly dragger
grnddwn's Avatar
It'll work but you would be better off with two of them. Your compreeesor won't have to run just to get you up.
grnddwn is offline   Reply With Quote
Old 11-24-2003, 10:59 AM   #3
Izzy
Trucker.
Izzy's Avatar
I agree and the more you run your compressor filling that one tank the harder it's going to be on the comp.
Izzy is offline   Reply With Quote
Old 11-24-2003, 05:02 PM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
If you are asking will it be enough to get you up on one cycle from aired out to ride height, I will have to say maybe, maybe not.
It might be enough volume, if you have a compressor that can pump enough psi. If your compressor cuts off at a low psi, then it probably won't have enough volume to re-fill the bags.
If you don't mind having two tanks, add another 3 gallon. If you just want one tank, sell the 3 gallon, and get a 5 gallon instead.
Even with two 5 gallon tanks, my system cycles every other time on my 77...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 11-25-2003, 02:02 AM   #5
brad2
I am only running the three gallon tank on mine. I pretty much don't even mess with my bags so it's not a big deal. It has only enough to go from empty to aired up before the compressor kicks on.
74 swb
71 2wd Jimmy
82 2wd Blazer
brad2 is offline   Reply With Quote
