![]() Join Date: Jan 2016
Mounting bolt question
What are these bolts (not the hinge bolts) holding together and are they oriented correctly? I ask because as you can see on the other side there is only the lower bolt and it is oriented with the bolt on the inside and the nut on the outside with the upper bolt is missing. Not a big deal just want to make it right.
1967 C10 Step side 1970 AMX 390 1977 Datsun 280Z highly modified with '95 LT1 power |
| Bookmarks |
