Junior Member
![]() Join Date: Nov 2018
Reduction gear starter
Hey guys, anyone know for absolutely sure where to get a gear reduction starter that will fit a BB 402, automatic 400, 168 tooth flywheel? I just bought one from NAPA that the paperwork said would fit,it didn't. So, now I'm stuck with a $270 starter that is useless to me. If someone knows where to get the right one, and maybe the part number, I would appreciate the information.
Re: Reduction gear starter
Powermaster 9526 - Powermaster XS Torque Starters
Powermaster 9612 - Powermaster Mastertorque Starters |
Junior Member
Thank you sir. I think I saw those on Summit. Have a good day!
Another option is the gear reduction from a gm 8.1 big block. Get the starter bolts from a dealer. You need 1 of each bolt. Total cost is less then $7 bucks and fit the best.
Part Numbers
AJC |
Junior Member
Thanks, AJC
At the body shop.
337-1022 ac delco $100 usually from Amazon.
678-107 Dorman x2
" That didnt make it any newer " " Dont antique the equipment " Last edited by KQQL IT; 01-15-2019 at 10:22 AM. Reason: Pn add |
Junior Member
I'll check it out. Thanks.
Junior Member
I took it back. I got a lady salesperson who knew very little, and I now own an expensive wheel chock. To the guy with all the tooth counts and mounting locations, thanks, but that doesn't make this starter fit my motor.
At the body shop.
Have them on 3 of my 4 vehicles two 454s and one 400 sb and it starts with 36° initial timing.
" That didnt make it any newer " " Dont antique the equipment " |
Who Changed This?
![]() Join Date: Jan 2013
Looks like you now have it under control, but I bought mine at a local speed shop and luckily got it right the first time. A good counter person makes all the difference in the world. It doesn't seem to engage a lot of the flex plate (which is the original, at 217k miles). The flex plate will be replaced soon.
Junior Member
Thanks guys, I appreciate the help. I should have got on here first, but the guy who sold me the starter was sure it was correct, the paperwork says it will fit a big block, a small block and even a 4.3 V6. Maybe if they all had the small flywheel. Oh well, expensive lesson learned. I'm gonna see if my credit card company can help me out with returning the starter, but if not, lesson learned. You fellows have a great day.....Warren
#12 | |
![]() Join Date: Feb 2019
1968 C20 Fleetside 396 4sp PS PB AC CST . https://www.youtube.com/watch?v=RWK8GgWD4uA |
#13 | |
AJC |
#14 | |
Whatever parts store sold you the wrong part and wouldn’t take it back sux.
