01-15-2019, 05:06 PM | #1 |
lowering a 1980 Big 10 short bed
Getting ready to lower 1980 Big 10 short bed. I think the front suspension is pretty straight forward. In the back with heavy duty rear leafs . Do i remove some springs from spring pack or get a set of normal C10 spring from a junkyard. Is the Big 10 rear leaf longer or the same as the normal rear leaf. Any help or suggestion on kits or anything would greatly be appreciated.
01-15-2019, 07:21 PM | #2 | |
Re: lowering a 1980 Big 10 short bed
How low do you plan to drop it?
01-16-2019, 01:44 AM | #3 |
Not sure how low you going for. I did a rear flip with the big 10 springs, didn't change anything with the springs. On ocassion the axle has hit the frame but rarely, and hasnt hit since I put new shocks in. I think it rides really nice with the big 10 springs. Ignore the mismatched tires, going to swap them around when it warms up.
1977 Chevy C10 SB, Turbo 5.3ls, TH400 |
01-16-2019, 05:07 AM | #4 |
Truck looks great. Is that 4 1/2 --6 drop. That's what I'm looking at. Thanks
01-16-2019, 11:01 AM | #5 |
Its close to that, not sure what it ended up at. Front is 3" spindles and cut springs. Rear is a flip kit.
01-17-2019, 01:14 AM | #6 |
Not a short bed , big same train of thought when lowering .. Here is a picture of his 1979 Chevy C10 with a 4 - 6 drop .
