Old 01-15-2019, 05:37 PM   #1
toddboetzel
toddboetzel's Avatar
1963 to 1972 Boyd Welding Aluminum Tank for sale
Brand new aluminum Boyd Welding tank for sale fits 1963 to 1972 Chevy C10 it has the side fill, 0-90 Ohm sending unit, Stealth 340 pump, standard 1/2" NPT rollover vent. Brand new, mounted in frame of new build using Boyd's universal mounting brackets, so the side brackets that are welded onto the tank have the 3 holes drilled in them. The only thing you will need is the universal mounting brackets, unless you just drill holes in your frame and use washers with nuts and bolts. I ended up needing the A1000 Stealth pump as I upgraded too many things on my LSA motor and I could not swap pumps as the tank is built differently to accommodate the bigger pump, so now I am buying a brand new boyd tank same as this with the Stealth A1000. I am doing the side fill because I am filling the stake pockets on the bed and on the back left corner stake pocket spot I am going to put in one of the Harley style gas caps and run my fuel hose up through that stake pocket and make my tank fill there. It currently sells for $765 plus $48 for mounting brackets, plus shipping. I will sell it for $600 plus shipping unless you live near me in Florida and want to pick it up.
Thanks,
Todd
toddboetzel is offline   Reply With Quote
Old 05-01-2019, 01:32 PM   #2
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Re: 1963 to 1972 Boyd Welding Aluminum Tank for sale
Did this ever sell?
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 05-01-2019, 02:42 PM   #3
michael bustamante
michael bustamante's Avatar
do you have to notch the bed crossmember to get the bed to sit correct with this tank? also, if im reading correct this tank is equipped with an internal pum for LS conversions? mine has the return style. does this have the return as well?
1967custom
michael bustamante is offline   Reply With Quote
