01-15-2019, 07:30 PM | #1 |
Upper door seal - what type of adhesive?
Curious what type of adhesive y'all are using on your upper door seals? #2 in the picture:
77 C10 Silverado SWB - LS Swap, mechanical resto-mod 05 Z71 Silverado RCSB - 5.3L LM7, 76mm turbo, 4L80e |
01-15-2019, 08:05 PM | #2 |
Re: Upper door seal - what type of adhesive?
I saved this video, for when I do mine.
https://youtu.be/qDBojIza-TA
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR |
01-15-2019, 08:11 PM | #3 | |
01-15-2019, 08:27 PM | #4 |
Yes, it’s an adhesive for rubber. You can get it at your local auto store.
https://shop.advanceautoparts.com/p/...B&gclsrc=aw.ds
01-15-2019, 08:34 PM | #5 | |
01-15-2019, 08:44 PM | #6 |
Which 3M product would you recommend to use on the cab seals (thick ones)? I notice there is a gluey substance leftover when I removed them.
01-15-2019, 08:46 PM | #7 |
I didn’t use anything on my cab seals.
01-15-2019, 08:51 PM | #8 | |
https://shop.advanceautoparts.com/p/...8008/7720004-p
01-15-2019, 10:20 PM | #9 |
I am guessing that the upper door seal is optional, since none of the 3 squares I have owned have had them. Would it help with wind noise on the highway?
01-15-2019, 10:48 PM | #10 |
01-15-2019, 11:21 PM | #11 |
My squares were 73,76, and 83.
01-16-2019, 01:25 AM | #12 |
Tucson the seal definitely help for the whistling sound when goin down the highway. but if you're wing window seals are not good that will cause whistling sounds too, really annoying
01-16-2019, 06:09 AM | #13 |
I got mine, for good measure. But after having the vent windows rebuilt and all new seals for the door and cab, it quieted down a lot. I never got around to doing the upper seal, there really hasn’t been a need to now.
01-16-2019, 08:53 AM | #14 |
Yes.
Any time there was a big management push to fix wind noise the seals got added. Immediately after that there would be a big management push for cost cutting measures and the seals would be the first to go. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
01-17-2019, 01:29 PM | #15 |
I just added them to my 90 K5. Got them from Precision. They have a metal tab at each end for a screw. They still need adhesive for the length. I had a tube of the 3m yellow stuff. Started with it. Ran out. Then went and bought some of the 3M black. Think it is called "3m superblack". The black stuff is way better than the yellow.
01-17-2019, 01:34 PM | #16 | |
Posted via Mobile Device |
01-17-2019, 06:47 PM | #17 |
Mine has the metal tabs also.
01-18-2019, 05:37 PM | #18 | |
01-18-2019, 05:42 PM | #19 |
#2 of your picture. That is the one I’m talking about. It came with a metal tab, to put a screw into the door, on the end of the seal.
01-18-2019, 06:08 PM | #20 |
Ok this is the one I'm referring to:
https://www.prp.com/product/detail/1...l=C10&type=All https://www.gm***************/thread...ripping.14112/
01-18-2019, 06:25 PM | #21 | |
01-18-2019, 07:53 PM | #22 |
01-19-2019, 04:24 AM | #23 |
Anyone know if the seals can be used on the rear-doors of a crewcab or Suburban?
I'd like to add them to all four if possible. Thanks, |
01-19-2019, 05:09 AM | #24 |
Rock auto list one set as working all four even though it list for 87 GMC 2 door pickup truck............
https://www.rockauto.com/en/catalog/...therstrip,1430 .............but where ever you decide to get them from you just need to find the proper ones for your vehicle according to their fitment guide where purchased from....
http://i204.photobucket.com/albums/b...baae5d9a7e.jpg |
01-19-2019, 07:35 AM | #25 |
I don’t see why you couldn’t.
