Old 01-17-2019, 12:39 AM   #1
bullmecha
72 C10 payload
Hey all,
Lurked around getting info here for awhile, great bit of reading I will admit. My issue is this, can I raise my payload capacity by getting different coils on my truck? I use it as a DD but i do actually haul loads most of the time. Maybe my originals may be worn out but I loaded it today with 1 4x8 3/4 ply, 12 2x6 8ft, and maybe 16 2x6 4ft. I was gonna keep adding but she squatted down to just below level and it is stock height. Any advice is welcome. Thanks and keep that info flowing.
bullmecha is offline   Reply With Quote
Old 01-17-2019, 10:33 AM   #2
clay68c10
clay68c10's Avatar
Re: 72 C10 payload
There are heavy duty rear springs out there, as well as helper air bags that fit inside your existing springs, and the old stand by air shocks.
Do some searching in the suspension part of the forum and that should give you more information.
Welcome to the forum, lots of good people and info here.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 01-17-2019, 10:47 AM   #3
notsolo
notsolo's Avatar
Re: 72 C10 payload
Short answer to stiffer coils is yes....Comes with a stiffer ride most likely. Replace with simular to originals and all the things, Clay 68c10 said....Welcome aboard...post some photos.
notsolo is offline   Reply With Quote
Old 01-17-2019, 04:55 PM   #4
HO455
HO455's Avatar
Re: 72 C10 payload
There were factory overloaded springs available with the HD spring opinion. The 67-72 version was a single leaf and the earlier trucks were multi-leaf. Using these or a helper air bag system would allow you to have the 1/2 ride with an increase in hauling capacity. These seem to come up for sale regularly in the classified sections or if your lucky at a local junk yard.
RIP Bob Parks.
Old 01-18-2019, 03:22 PM   #5
bullmecha
Re: 72 C10 payload
So that single spring in the first picture is something I can add to mine I believe. My truck had the leaf brackets on it when I bought it but I have removed one side already to add a frame mounted hitch. Might have to get that put back on and not use a hitch, or figure a way around it. Thanks for that info 455
Old 01-18-2019, 06:24 PM   #6
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Re: 72 C10 payload
From what you staed your nedds are I agree the factory overload springs along with a good set of shock absorbers should work for you. I have the overloads on my truck and new shocks and I have occasionally hauled heavy stuff and the truck doesn't squat.
1992 K1500 GMC Suburban
" In the end, we only regret the chances we didnt take "
" Time is the only currency we spend without knowing the balance, use it wisely ." ..
Old 01-18-2019, 08:13 PM   #7
WorkinLonghorn
WorkinLonghorn's Avatar
Re: 72 C10 payload
3-400 Lbs. of lumber should not bottom your springs. You need new springs period IMO.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 01-19-2019, 09:11 PM   #8
Steeveedee
Ram-A-Lam-A-Ding-Dong
Steeveedee's Avatar
Re: 72 C10 payload
Yup! I know a farmer in Idaho who had the bed of his truck (C/10) filled with grain. About 2 tons. It was riding on the bump stops. He stopped at the shop I was working at to get a tarp from his son so the grain wouldn't blow out too much. He drove that thing about 8 miles to his farm like that...at about 5 MPH.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 01-19-2019, 09:26 PM   #9
treveiger
treveiger's Avatar
Re: 72 C10 payload
This is what I have on my truck. We hauled a lot of retaining wall bricks and among other things. I think our record weight was 3500lbs in the bed. Not the smartest but it was all I had at the time.
1969 Chevy c20(Miss Hackjob)
treveiger is offline   Reply With Quote
Old 01-20-2019, 10:27 PM   #10
Steeveedee
Steeveedee's Avatar
Re: 72 C10 payload
Then again, I was putting an addition on my previous house. I went to the BORG and got a ton of shingles and loaded it in the back of my '56 Chevy 210 wagon. I drove slowly going home, because the headlights were looking at treetops, and I could steer it with one finger (no power steering). The way we sometimes abuse our vehicles.
~Steven
Simi Valley, CA
Old 01-23-2019, 12:23 AM   #11
da.slyboy
Re: 72 C10 payload
I thought a simple method was to also replace with c20 springs? They are rated higher and will be stiffer but should be easy to swap out.
da.slyboy is offline   Reply With Quote
