landarts
![]() Join Date: May 2005
1972 GMC K20 4x4 Custom 2500
1972 ¾ ton GMC with big block motor I believe 402, automatic TH350 transmission, 205NP transfer case, power disc brakes front, power steering, 16” steel wheels
Link to build thread to see what has been done and where it came from - http://67-72chevytrucks.com/vboard/s...d.php?t=748755 The truck runs great and drives even better. Has lots of power and sounds amazing with the dual exhaust. This truck has made a nice transformation and will make someone a nice driver truck or take it to the next level and do a complete body paint and new trim. All the usual rust items have been completed and the truck is solid. If you follow the link above there are several pages of pictures to see how the work was done and where it needs to go. The items that were painted were done with single stage paint and are driver quality, just did not want to leave front fender and bedside different colors. Listed below are the new items replaced or added to truck. Asking price is $8500 Items below are what has been replaced or fixed Drive Train - new radiator - new radiator and heater hoses - new electric fuel pump, fuel filter and hoses - new fuel sending unit - 3 way valve and hoses (removed not used) - new pvc valve and oil fill cap - new battery and new cables - new rag joint for steering shaft - replaced some wiring - new oil, antifreeze, transmission modulator, fluid and filters - new 4 tires 235/85R16 - new carburetor - new carburetor mount spacer - new distributor cap, rotor, plugs and plug wires ( distributor is a Mallory Unilite electronic ignition) Interior - new dash pad - shifter knob - new heater control switch and heater lever replaced - new heater core - new seat cover - new floor underlayment - new carpet kit - new dome light - new arm rest both sides - new door weather strip at bottom only - new door sills - new inner door handles - new steering upper bearing - new turn signal springs Exterior - new rear lens kit - new inner rockers - new outer rockers - floor sections (fabricated parts) - front mounts (repaired not replaced – cut out section and replaced with new metal and treated) - lower passenger outer door (fabricated parts) - new single stage paint for new metal repair areas - used donor panels for front passenger fender and drivers bedside - new bed bolts - new plastic clips for trim replacement Items missing, needing attention or need replaced still - windshield is cracked - tailgate is missing trim - gas gauge not working, never removed cluster to check - tachometer mounted on column is not hooked up - need to bolt the rear bumper back - I will do
Super Cheyenne aka the "Devil Cowboy" 71 K20 Idaho Edition 69 K10 from the Field 68 Second Chance Fix and Sale 72 GMC 3/4 ton 4x4 K2500 The "Fixrupr" build thread 72 Cheyenne 1/2 ton " FIXRUPR " - daily driver 67 C20 all original paint 71 K20 Custom 4x4 (Idaho Edition) 72 K20 GMC Super Custom 4x4 69 K10 Custom package 4x4 (69 K10 from the field) 72 K10 Custom 71 K10 Custom 69 K20 Custom Deluxe 4x4 71 K10 Custom Deluxe 72 K20 Crew Cab Project 71 GMC Jimmy CST 70 Blazer |
| Bookmarks |
