Old 01-17-2019, 06:40 PM   #1
whitels1
whitels1's Avatar
LS1 Swap 79 Chevy K20
LS1 Swap 79 Chevy K20 - I have other build threads on my trucks, the link is in my sig. I wanted to make a dedicated thread for the LS swap portion of this build, and show how I'm handling it on this particular project. I would still encourage anyone getting ready to do a swap to browse through the great builds in this section. Here goes.
Engine:
5.3 block bored, with LS1 pistons.
LS1 Heads.
Truck oil pan,
Truck Intake, with returnless rail.
Truck Coils.
Truck Accessories.
Drive by cable throttle body
Stock Radiator.
Stock Fan shroud.
Stock Engine crossmember.
2005 Silverado Air box, intake piping and battery tray.
411 PCM.
Painless Harness.
99 Fbody Exhaust Manifolds(for now)
Stock LS1 cam (for now)
Transmission:
I plan to run a 4L80E(2wd long slip yoke), attached to an NP205, using an adapter from Advance Adapters. The transfer case was originally from a figure 8 SM465, and has already been machined.
Fuel System:
87 K5 Blazer, TBI gas tank (BAFFLED)
87 K5 Blazer, sender assy upgraded with an EP381 Delco Pump.
-6 Russel lines and fittings.
LS1 Corvette fuel filter / regulator.
Here are the first two videos of the swap, which I'm currently working on. If you have questions fill free to ask.
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
whitels1 is offline   Reply With Quote
Old 01-17-2019, 06:53 PM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: LS1 Swap 79 Chevy K20
Nice swap....!!
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 01-18-2019, 02:09 AM   #3
whitels1
whitels1's Avatar
Originally Posted by mongocanfly View Post
Nice swap....!!
Thanks man! It's getting there.
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
Old 01-18-2019, 12:24 PM   #4
whitels1
whitels1's Avatar
Video #3 for the LS1 swap. Lot's of projects within the larger project. In this video I fab'd up some supports for the battery tray and air box plate that came off the 2005 Silverado. Almost seems like the little projects take the most time, but it's cool to look at something when it's done that you had no idea what you were gonna do at the beginning.
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
Old 01-25-2019, 12:58 PM   #5
whitels1
whitels1's Avatar
It's fuel system time! Parts installed: 87 Chevy K5 baffled fuel injection tank, New pump module(replacement for a stock 87 Chevy K5 tank) with upgraded EP381 pump P/N: 25163473. Russell -6 AN braided fuel line, Russel fittings. Wix 33737 fuel filter / regulator. The fitting for the outlet of the filter is a Russell 640940.
Parts used:
Fuel tank:
https://www.summitracing.com/parts/rnb-576-313
Fuel pump module:
https://www.summitracing.com/parts/sgt-sp12l1h
Fuel fitting x6
https://www.summitracing.com/parts/rus-610025
Fuel fitting x2
https://www.summitracing.com/parts/rus-644123
Fuel fitting x1
https://www.summitracing.com/parts/rus-644113
Fuel hose x1
https://www.summitracing.com/parts/rus-632093
Fuel hose x1
https://www.summitracing.com/parts/rus-632073
Fuel fitting x1
https://www.summitracing.com/parts/rus-640820
Fuel fitting x1
https://www.summitracing.com/parts/rus-640830
Fuel Pump x1
https://www.summitracing.com/parts/ado-ep381
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
