Old 01-19-2019, 02:26 PM   #1
WyattTX
Is there a permanent fix for the split AC system in GMT800s?
In my 2004 2500 HD 4x4, the one side of the cab blows cold air, and the other doesn't. It has done this 2 times before, and it was fixed with a new actuator motor both times. I'm getting tired of this. Can I just eliminate the blend door entirely, and just not have a split system (assuming that's all that's blocking the air flow.)? All I want is the same air temperature, and pressure coming out of all the vents. I couldn't care less about having a split system. I just want cold AC. I'll be honest I dont know how these HVAC boxes are set up, so I would appreciate some input before I make the situation worse. Thanks.
WyattTX is offline   Reply With Quote
