Old 01-20-2019, 12:01 PM   #1
44boggers
Where can I find this part??
Maybe I am typing it in wrong, but I can not seem to find this air flap anywhere online. Mine is split all the way down the middle so basically it is useless.
44boggers is offline   Reply With Quote
Old 01-20-2019, 03:05 PM   #2
TKCR
TKCR's Avatar
Re: Where can I find this part??
https://www.oldairproducts.com/produ...s/vacuum-parts
Old 01-20-2019, 03:14 PM   #3
44boggers
THANks but i am referring to the plastic part. Not the actuator.
Old 01-20-2019, 05:36 PM   #4
tucsonjwt
Can you tell us what year truck you have and where exactly the plastic part goes? Is it something to do with the a/c ductwork? I can't tell from the flat plastic what it might be.
tucsonjwt is offline   Reply With Quote
Old 01-20-2019, 05:42 PM   #5
44boggers
Yeah sorry. Its an 83 c10 with AC. This part goes on the pass side under the hood cowl.
I believe it allows fresh air in once vacuum is applied to the actuator. The actuator should push open the flap. But with my piece the flap is split open where it should "pivot" so basically its useless.
Old 01-22-2019, 12:32 PM   #6
44boggers
Any one else have an idea on where to find a replacement part?
Old 01-22-2019, 02:12 PM   #7
andyh1956
Is there enough material left on the broken side that you could fasten another piece to it?
I wouldn't worry too much about it anyway, they don't block much air on Recirculate to make a big difference!
andyh1956 is offline   Reply With Quote
Old 01-22-2019, 03:16 PM   #8
Mr_Rich
Mr_Rich's Avatar
Clean it very well and plastic weld it. A lot of these plastic parts are unavailable and the only way to fix the problem is repair the part. Find the compatible plastic and weld it in. It's probably PP plastic, but could be something else. Start viewing YouTube videos on plastic welding to get a good idea of what's needed. Sometimes just a simple soldering iron with the correct tip will do the job. I repaired a radiator shroud on the '97 K2500 I have with this technique.
1989 K1500 Chev. EC
Original owner; some of the aftermarket parts I've installed are Borla headers, Hypertech chip, Edelbrock water pump, and a Stillen rear disc brake conversion kit.
2009 Hummer H3T 3.7L 5M (sold)
1997 K2500 Chev. EC 7.4L/ 4L80E
2018 Dodge Ram 2500 HD R/C
Mr_Rich is offline   Reply With Quote
Old 01-22-2019, 03:18 PM   #9
Mr_Rich
Mr_Rich's Avatar
And I add that you can't hurt it any worse than it already is...
1989 K1500 Chev. EC
Old 01-22-2019, 05:23 PM   #10
44boggers
This was my first thought actually, just to plastic weld it back together. But I was thinking how that section still needed movement and maybe welding it would restrict the movement of the flap making it useless. Maybe I stitch weld it and use silicon in between which will allow it to flex.
Thanks for the feedback.
Old 01-22-2019, 10:09 PM   #11
mongocanfly
Post Whore
mongocanfly's Avatar
Any chance you could use a small piano hinge on it?.....
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 01-30-2019, 10:46 PM   #12
83GMCK2500
Can try searching by part number, might find one or be able to use it for reference when contacting places:
http://www.gmpartswiki.com/getbigpage?pageid=58273
Devin
1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt
1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050
1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350
My Introduction with my '83s History
New Daily, the '96
83GMCK2500 is offline   Reply With Quote
Old 01-31-2019, 07:27 AM   #13
Wgesnerjr
Wgesnerjr's Avatar
Since its the hinge part that broke, any repair will have to be flexible. piano hinge is a good idea but it may rust since it's out under the cowl. I might try making a hinge out of vinyl from a fabric store. once glued on each side, it should keep it in place, give the flexibity to open and close, and not rust in the long term.
Jay Gesner
Atlanta, GA
1985 C10 Long Bed 4X2
LS 5.3, 4L60E
Father/Daughter Project
Wgesnerjr is offline   Reply With Quote
Old 01-31-2019, 05:09 PM   #14
44boggers
Thanks for all the tips guys. I dont have much time right now to get on to fixing this. But when I do I will post back up.
Paul
Old 02-01-2019, 12:21 AM   #15
LT7A
A piece of innertube and staples?
Old 02-02-2019, 12:11 AM   #16
gmachinz
Those AC enclosure assemblies are quite the trick to restore back to original function! I’ve restored several and yes parts are very tough to obtain. I’ve even thought about creating a seperate business offering restored AC assemblies but the cost and labor to do one I’m sure is more than 90% of people would pay for-and the 10% of those who would isnt enough to make it worthwhile. I suggest some good ole fashioned junkyard time taking a few apart until you find a good one for parts. Again, Suburbans make great donor trucks!
gmachinz is offline   Reply With Quote
Old 02-11-2019, 12:08 PM   #17
Big Blue
Big Blue's Avatar
Hay 44, I sent you a PM.Do you still need the flapper for the outside air ? I was taking parts off a scrapper truck I removed the piece. If you still need it I will send it to you just pay shipping.
See Ya John
Big Blue ( John )
79 Chevy Pick up.....My Dailey
STILL Working on a frame up: 1987 Truck body on a 78 Blazer frame. Need cab blasted to start project. Got the cab BLASTED, Now Prep and Paint. Started to lay SOME BONDO and primer. Done, Ordering paint. Got paint, Stuff painted,Cab,Fenders, Hood more later. 9/7/2015 Got the clear coat on,now time to take one off. Started to put things back (What a nightmare) like the heating and AC stuff,inside wire harness, outside AC unit and booster, still more. May 2016, still working on the inside. Got duck work in,heating and AC. Radio (stock) in dash with after market in console later, Speaker are hooked up, Steering column is in. Getting ready to drop the cab onto the frame, Working on engine now since I have the room. Well here it is 2018, got the engine in and it runs, now I need to get the exhaust system in so I can adjust the lifters, to loud right now. Got the exhaust on now I am waiting for the break parts to come in.
Big Blue is offline   Reply With Quote
Old 02-15-2019, 10:59 AM   #18
Big Blue
Big Blue's Avatar
Since I did not get any response back from 44boggers, I am offer the same deal to anyone else. It is free except you just pay the shipping cost.
John
Big Blue ( John )
Old 02-15-2019, 11:12 AM   #19
44boggers
John
Hey John
Sorry I have been offline. I did not get a pm from you. But yes I am interested in your ac part.
Please send me another pm with some details.
Thanks buddy
Paul
Old 02-15-2019, 04:57 PM   #20
Big Blue
Big Blue's Avatar
PM Sent
Big Blue ( John )
Old 02-22-2019, 10:57 AM   #21
Big Blue
Big Blue's Avatar
Hello 44boggers, I sent you a PM. Package was sent out today, You should get it by Monday the 25th.
Thanks John
Big Blue ( John )
