New hood hinge bolts don't fit.
Ordered these from classic industries last summer. Just now tried to use them and realized the small ones are the only ones that fit. Threads are correct, all 5/16 fine thread. The shoulder is to not. 4 of the bolts have a 7/16" shoulder, the other two are 3/8" shoulder. all of the hinge straps and spring arms have a 3/8" hole. Any ideas? Nick
Fast, Cheap, Reliable. You may pick two My 47/S10 build http://67-72chevytrucks.com/vboard/s...d.php?t=679723 |
Re: New hood hinge bolts don't fit.
Do you know anyone with a metal lathe who could turn the shoulders down?
I could turn the shoulder down in the bolts or drill out the hinge straps. I'm just trying to figure out if the bolts are wrong or if certain years had different holes in the hinges.
Those bolts worked fine on my 1953 Chevy Truck 3100
53 Chevy 3100, SBC 355, 700R4, S10 frame, Ford 8.8 rear with 4.11 gears, front disc & rear drum brakes |
Do you have your hinges mounted correctly? Are the right ends connected to the cowl? They're not inverted?
1951 Chevy Panel Truck |
I am thinking to show the photos of your hinges and also to take another look at if those bolts will fit. I am thinking there is paint and primer in the hinge or the one you checked had a burr in it so the bolt wouldn't go in, something doesn't sound right here.
Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
Still riveted on the firewall side. Hole is definitely 3/8", no rust or paint.
Two of the six bolts I have are for a 3/8" hole. The other 4 are 7/16".
![]() Join Date: Jul 2007
It's too late, dark, went and cold to go out and look on the easy to get to cab tonight but I'll try to remember in the morning. I've never seen one that didn't use 4 with the 7/16 Shoulder and 2 with the smaller shoulder.
![]() Join Date: Sep 2011
Working off memory here but pretty sure that the big truck hinges has a different hole diameter in the hinge opening. With that being said in the last 60 plus years they who knows what owners trucks have on them now. As you know (fellow Nebraskan) it about 15 degrees right now so cannot check the ones I still have on trucks. Well I can , but don't want to HAH! . The thing about the repo world is they never check accuracy and or fitment of parts they makeThey just grab something off an old truck and send it to China . So if they grabbed a set of large shoulder bolts and ship them off this is what happens . I think you have the correct small hole hinges (pickup) . I think the bolts , especially the larger ones are for a big truck. Like a say. If it warms up a little I will check some of my trucks to verify. Good luck with you truck. I raced motorcyles in Hoskins many moons ago. Good times .
#10 | |
How long ago did they race motorcycles in Hoskins? I raced stock cars out at Riviera from 97 through 07. The good days when somehow I had more money and time lol. Nick
Raced from 73 to 79 . Hoskins had a nice little sand track . That truly was the good old days . No cell phone , no computer , more money , more time , made a deal on a handshake ....... .
On a different note . Check post 35 of your build thread. The hood hinge bolts you took out appear to be the same diameter but hard to tell from the photo. Not laying in a bucket somewhere you could measure? When it warms up I will check. |
#12 | |
#13 |
Small world . Cornie is still going as is Hydraulic Service . I think his kids are more active in the business but still going. Pretty sure they have been in business for over 40 years.
#14 |
Brother worked there for over 25 years.....had to quit when he had a stroke. We lost him last March (2018). His wife still lives in Seward.
#15 |
![]() Join Date: May 2007
I used that same kit on mine, one pair of smaller shoulder was correct on my application.
also, mine didnt fit well till I emery papered the holes, they had a fair amount of sticktion going on and were pretty grabby. 1/16ths on a circle is 1/32 or ~31 thousandths, which I agree is a lot of difference, but maybe just maybe some sanding will help. wait till you try to put them on the hood! I would say put the hinges and springs on the hood first, then onto the body. there isnt a letter in the alphabet that I resembled when standing up, bending down, twisting right, and trying to see over my shoulder from under my armpit, like I did trying to put those bolts on hinges that were already installed. the shoulders also didnt want to seat till I ran the hood up and down a few times. imagine playing ring toss, now imagine playing ring toss with a ring an inch thick that matches the bottle diameter almost exactly.
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
#16 |
I've already decided when the hood goes back on the hinges will be attached to the hood first And the firewall second. It was awkward as it was pulling the hood with the front clip removed. No way in hell do I want to try and line those up.
#17 | |
I have parted out many of these trucks in the last 40 years and something I had never checked. One thing I noted on your build thread is that you have a 47 . Over the years I noticed the 47 model year trucks were kind of a learning year curve for GM . For instance the bolt pattern of the gauge clusters is different than later years, different glove box hinges , different glove box mounting and rear cab mounts. These were all changed in later years . There are also many other differences. So , I do not have a final answer on your bolts other than they MAY have been an earlier production item. If I get my hands on a original 47 I will grab the bolts and hinges to see if they are different . Sorry this thread kind of veered off course. Good luck with your truck . I looked at your build thread . Great job. |
#18 | |
Thanks for the kind words on the build thread. It's going pretty slow and right now it just looks like a bunch of crap piled together but hopefully before long it'll start actually looking like progress. Nick
| Bookmarks |
