Old 01-20-2019, 03:50 PM   #1
spudder
Active Member
Trailing arm perch spacing.....measurement.
I've searched but haven't found the center line dimension between the trailing arm perches. Planning on swapping a mid '80s rear end into a '64.
I want to go ahead and get the rear end modified for the swap by adding a panhard bar bracket and the trailing arm perches.
The truck is going to be at stock height so pinion angle won't change.
Can anyone provide these measurements:
1) trailing arm perch side to side center line distance
2) original pinion angle
I don't have an original rear end here to measure. That's why I'm requesting help from the forum.
spudder is offline   Reply With Quote
Old 01-20-2019, 08:28 PM   #2
bigmoe
bigmoe's Avatar
Re: Trailing arm perch spacing.....measurement.
I just put a square body rear end in my 65 bare frame. It's kind of hard to weld your perches on at the proper pinion angle with the axle out of the truck because the perches don't sit level like with a leaf rear suspension. Sitting on the trailing arms they lay at an angle. What I did was bolt it all together without welding the perches. The rear u bolts at the widest (rearward) are 41 3/4" on center. Get it centered left and right and snug it up slightly with the pinion pointing slightly upward. Then with the full truck weight on the wheels measure and adjust it to the proper angle. Once you get it set tack the perches, then lower the axle and fully weld it.
bigmoe is offline   Reply With Quote
Old 01-21-2019, 01:01 AM   #3
Captainfab
60-66 Nut
I could get you that info when I get to my shop tomorrow, if someone else doesn't first.
Old 03-05-2019, 01:15 AM   #4
ivanandjuri
I am swapping a 1999 ford 8.8 into my 69 c10 what useful info could you give me? I’ve already shaved all old perches off and ordered new perches to weld on.
ivanandjuri is offline   Reply With Quote
Old 03-05-2019, 07:30 AM   #5
PGSigns
PGSigns's Avatar
Here is a way to get the pinion angle set. Bolt the rear in the truck with out the springs or shocks hooked up. Ensure it is centered with the trailing arms. Raise the rear end up to the desired ride height and set it on jack stands. Then match the angle of the rear to the angle of the trans or the front drive shaft depending on one or two piece drive shaft. Tighten the ubolts till they are firmly holding the rear and recheck your angles. Tack weld the perches and remove the rear end. Stitch weld the perches to reduce how much heat you put into the housing so that you done pull the ends out of alignment.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 03-08-2019, 01:09 PM   #6
demian5
demian5's Avatar
And to eliminate the issue of the panhard bar mount, just get a deluxe track bar kit that has a longer bar and puts the mount on the trailing arm with a new bracket.
I just did this when swapped out a 80s caprice classic (5 on 5 bolt pattern) posi rear diff. It has perches for a 60-62 on it and a track bar mount. Trying to get rid of it. Its kind of wide.
When I put the rear 12-bolt in out of a late 60's truck, I had the luxury and was able to use the existing perches to get the right pinion angle when the new, wider apart ones were installed.
Here is what I had to do:
http://67-72chevytrucks.com/vboard/s...0&postcount=23
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 03-11-2019, 03:37 PM   #7
Tonys1963
Im curious to see how well this fits. Will the offset of the rearend cause an issue with the trailing arm mount? Im contemplating the same swap.
Tonys1963 is offline   Reply With Quote
Old 03-11-2019, 03:46 PM   #8
ivanandjuri
Old 03-13-2019, 05:56 PM   #9
scoot_mcgrute
I didn't have any problems from this swap last year. I did it the guess and check way by bolting the axle to the trailing arms, getting it mostly centered and then tacking it all together.
Mock up
Final install
1966 Army Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=691778
scoot_mcgrute is offline   Reply With Quote
Old 03-13-2019, 06:02 PM   #10
ivanandjuri
why did u use spacers inbetween perch and trailing arm?
Mock up
Final install
Old 03-13-2019, 06:09 PM   #11
ivanandjuri
Mock up
Final install
Old 03-13-2019, 07:58 PM   #12
scoot_mcgrute
I used lowering blocks, I'm at a 5/7 drop with my truck.
1966 Army Truck
Old 03-14-2019, 12:47 PM   #13
demian5
demian5's Avatar
Mock up
I want to see a picture of the passenger side shock mounted.
Doesn't that pan hard bar hit the cover?
1986 C20 Scottsdale
Instagram: C10sofOC
Old 03-14-2019, 01:54 PM   #14
scoot_mcgrute
I didn't take a picture of the passenger side shock but it is identical to the driver side shock, I used the No Limit rear shock relocation kit. The panhard bar does not hit the cover, there's still room to pull the cover without hitting anything.
1966 Army Truck
Old 06-17-2019, 05:35 PM   #15
drmatera
drmatera's Avatar
Ive got an 8.8 Explorer rear end for my GMC as well. My truck is a leaf spring set up but I'm considering the swap to trailing arms.
drmatera is offline   Reply With Quote
Old 06-18-2019, 02:54 PM   #16
ChadW
Im putting a chevy 10 bolt in my 66...so is the measurment from ubolt to ubolt on the trailing arms the same as above? 41 3/4" ??
ChadW is offline   Reply With Quote
