Old 01-21-2019, 12:12 PM   #1
Ken O.
No blinkers
What would cause the blinkers to not work? Replaced the relay already. I don't see any other fuses for the blinkers..??
Ken O. is offline   Reply With Quote
Old 01-21-2019, 12:48 PM   #2
AussieinNC
Moderator
AussieinNC's Avatar
Re: No blinkers
Model of truck please....
Family and country before all others...
2006 Chevy Silverado (Daily Driver)
2025 Chevy Equinox
AussieinNC is offline   Reply With Quote
Old 01-21-2019, 01:05 PM   #3
Ken O.
Re: No blinkers
sorry, 67 GMC.
Old 01-21-2019, 01:28 PM   #4
AussieinNC
Moderator
AussieinNC's Avatar
Re: No blinkers
Blinker fuse is marked TRFK...
Also check switch plug on column is connected....
2025 Chevy Equinox
Old 01-21-2019, 01:41 PM   #5
Ken O.
Re: No blinkers
Thanks, I'll take a look in a few min. Hard to see the writing on some of them, it's original.
Old 01-21-2019, 02:26 PM   #6
Ken O.
Re: No blinkers
There was one fuse blown but it wasn't the one I was expecting. No telling what's going on in this fuse block. If I told you some of the things I've found...
I'll replace it and see what happens. What amperage should it be?
Old 01-21-2019, 03:07 PM   #7
LockDoc
The Older Generation
LockDoc's Avatar
Re: No blinkers
It depends on which fuse it is. Here is one of the fuse blocks.
LockDoc
Leon
Old 01-21-2019, 03:16 PM   #8
Ken O.
Re: No blinkers
That's what the block looks like. It was the one between Heat and Radio, I assume that's the heater fan. But I used the heater this morning on the way to work and it works fine. So like i said, who knows what they did under there. I'm looking at a whole new wiring harness too just in case. Probably best...
Old 01-21-2019, 03:18 PM   #9
rockyrivermark
Re: No blinkers
This may be helpful also
My build page
http://67-72chevytrucks.com/vboard/s...d.php?t=764662
My cabinet building site
http://www.cbcabinets.com
rockyrivermark is offline   Reply With Quote
Old 01-21-2019, 03:31 PM   #10
LockDoc
LockDoc's Avatar
Re: No blinkers
If you will notice, the one Mark posted is a little different layout than the one I posted...
LockDoc
Leon
Old 01-21-2019, 03:37 PM   #11
Ken O.
Re: No blinkers
Thanks guys, they are both pretty close. I'll print one off and take it out there with me. You can't read most of what mine says anymore. I'll take a meter and pop the other fuses out and check them too. They look ok but that doesn't always mean anything. The one I found was clearly popped.
Old 01-21-2019, 04:00 PM   #12
'68OrangeSunshine
'68OrangeSunshine's Avatar
Re: No blinkers
Could be the Turn Signal Switch inside the steering column.
Old 01-21-2019, 04:34 PM   #13
LockDoc
LockDoc's Avatar
Re: No blinkers
Many times the fuse holder clips will be rusty too.
LockDoc
Leon
Old 01-21-2019, 05:00 PM   #14
Ken O.
Re: No blinkers
It stopped working before I replaced the whole steering column. Got that done this weekend and it still doesn't work.
Old 01-21-2019, 05:51 PM   #15
'68OrangeSunshine
Re: No blinkers
And you tested both bulbs?
Old 01-21-2019, 06:51 PM   #16
Ken O.
Re: No blinkers
I have not tested bulbs but inside dash flashers don't work and outside flashers don't work. I would assume I don't have ALL the bulbs bad but I'll check.
Old 01-21-2019, 08:39 PM   #17
Sheepdip
Sheepdip's Avatar
Re: No blinkers
You didn't by chance change the bulbs out to LED's did you?
Sheepdip is offline   Reply With Quote
Old 01-21-2019, 08:56 PM   #18
Ken O.
Re: No blinkers
Nope, not yet but that will come in the future some day.
Old 01-21-2019, 09:45 PM   #19
Andy4639
Old member
Andy4639's Avatar
Talking Re: No blinkers
Does the horn work? All the electrics for the turn signals work off the steering column wiring harness. Hot wire into column and signals out. If you don't have a horn then you don't have power coming in to the harness.
Signal wires are dark blue and light blue. Disconnect the horse shoe connector and test with a 12 v test light.
Wiring diagram is your best friend.
Even if the colors are different but the wire is ran correct it helps you find the mistakes.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 01-22-2019, 11:55 AM   #20
Ken O.
Re: No blinkers
Ok guys, I figured it out. much easier than we thought. This is an all brand new steering column and the hazard button was pushed in. I couldn't push it in and couldn't pull it out. So I searched on here and found that someone said it took a ton of force to pop out the hazard switch the first couple times. I went out and put some elbow grease into it and bingo! everything works. (except the hazards) but that's the relay I think. At least I can drive and not worry about a ticket for no turn signals. I appreciate all the helpful tips.
Old 01-22-2019, 02:49 PM   #21
LockDoc
LockDoc's Avatar
Re: No blinkers
Good deal! Glad it ended up being an eazy fix.
LockDoc
Leon
Old 01-22-2019, 09:35 PM   #22
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: No blinkers
If your lights didn't blink when the hazard switch was pushed in it means the switch is not getting power from the emergency flasher, which would explain why the turn signals didn't work when the hazard switch was in. Check the brown wire in the middle of the column connector for 12 volts constant power and if it has no voltage then the hazard flasher may be bad or the wiring connector may not be making contact on both sides. It is also possible that the TS switch hazard circuit is bad.
Start by swapping the two flashers and see if both flashers work the turn signals.
If neither one works the hazards then it's a power issue at the column connector or the TS hazard switch.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 01-22-2019, 09:50 PM   #23
Ken O.
Re: No blinkers
Once I pulled out the hazard switch the blinkers worked properly but the hazards still didn't work. I stopped at NAPA on the way home and got a new hazard module and that fixed the hazards. So everything works now. The Hazards have never worked since I got the truck as the switch was broken off. This is a classic "Work in progress". There are TONS of things I've fixed that I just shake my head and wonder what they were thinking... I've written it all down as I go and there is over a page of stuff.
