01-22-2019, 09:30 AM | #1 |
Front 4” lowering coil springs
Anyone use western Chassis front 4” drop springs? My 1965 Chevy truck has a front 1975 c10 stock suspension. My truck was a c20 and I had originally put gmc Paul’s 3/6 kit on specifically made for c20 but I ended up putting a 71-72 c10 rear and I did keep the 6” springs in. I was told 63-72 springs won’t fit 73-87 . I rather go a lil lower in front 4 and keep my 6 rear is just a nice touch. Not really wanting drop spindles. Anyways performance online isn’t far from me and I could buy them there.
Posted via Mobile Device |
01-22-2019, 02:23 PM | #2 |
Re: Front 4” lowering coil springs
I have a 1972 C10 with 4" drop springs from the previous owner.
This is just my experience but I have a lot handling issues with the front end. It hits the bump stops and also gives a lot of bump steer issues. I'm currently swapping the 4" springs for 2.5" drop spindles and 1.5" drop springs hoping to fix the front end issues.
Project Engine Stand 1972 SWB conversion: http://67-72chevytrucks.com/vboard/s...d.php?t=673914 1970 Nova: http://67-72chevytrucks.com/vboard/s...d.php?t=708161 |
01-22-2019, 07:24 PM | #3 |
never rode in 4" drop springs but from years of wrenching no way would i do this for many reasons .
split it up with drop spindles and coils . help each share the work load and make alignments much more easy to set .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
01-23-2019, 10:51 AM | #4 |
I don’t know why they sell them that low at performance online. I don’t see any reviews on them. I will most likely just get some 3” lowering springs.
01-25-2019, 09:01 AM | #5 |
https://www.ebay.com/itm/1973-87-Che...-/122802684623
I was thinking about these. Posted via Mobile Device |
02-02-2019, 12:46 PM | #6 |
The springs probably arent the issue with the handling. Sounds like the front end needs to be rebuilt.
On one of my trucks I run 4" springs and 2.5" spindles and it rides fantastic. This is without a sway bar so far. |
02-02-2019, 05:37 PM | #7 |
Yea I am rebuilding the front end. I’m just going to try them out and let everyone know how it goes.
05-01-2019, 10:30 PM | #8 |
50bomb. Have you tried them out yet? I thought about giving them a shot also. Thanks.
05-01-2019, 11:06 PM | #9 | |
05-02-2019, 07:58 AM | #10 |
4 inch springs make getting a good alignment on the front hard to do and introduce a bunch of bump steer into the system. I would use a combination of springs and spindles. I like 2" or 2 1/2" spindles and what ever spring gets you to the 4 inches you are looking for. Then while you have it apart do the caster mod to the lower control arms (1/2" will get you all you need). You will be able to get 4 to 5 degrees of caster camber will be easy to set with out the extreme angle of the upper control arm that the 4 inch spring gives you and the tie rod angles will be pretty flat keeping the bump steer under control. The springs for the 73-87 are the same as 63 and up.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
05-02-2019, 08:18 AM | #11 | |
05-03-2019, 07:05 AM | #12 |
Well They will fit from 63 to 87. The C20 springs may be a bit stiffer than the C10. On my 66 I have the 66 cross member, all the control arms, power steering, drag link, tie rods from a 78 and 73 to 87 drop spindles with 6 lug rotors. All this stuff will swap over including the complete cross member. If you go the the 60 to 66 FAQ section there is a lot of info as to what swaps over and how to do it. So all I'll tell you is i and many others have done it and they will go. Here is a link for front springs shows they fit 63 to 87.
https://westernchassisinc.com/1963-8...d-Coil-Spring/ Jimmy
05-03-2019, 08:03 AM | #13 |
Yea I don’t mind my ride being stiff. Before I did the 73-87 c10 front swap I removed my 8 lug 4.56 gears and installed 71-72 c10 5 lug 3.73....I re installed my c20 6” drop coils and it handled nicely. Yea I’ll give my front coils a try instead of spending more money.
12-10-2019, 01:21 PM | #14 |
Sorry to high jack. but any more info on this? is there a thread you can point to? i thought anything more than 5" (some say 4") in front drop was asking for trouble.
12-10-2019, 03:49 PM | #15 | |
Moderator
12-10-2019, 07:10 PM | #16 | |
What shocks? What size wheels? Tires? What alignment specs were they able to achieve?
