Old 01-22-2019, 11:31 PM   #1
1BAD65
Thumbs up >> Front Shock Relocators for 60-66c10 with 4/6 DROP???<<
I have been searching for the answer to this question for about an hour.
all I could find were plenty of threads for REAR shocks but nothing pertaining to the front shocks on our 60-66 C10 trucks with a 4/6 DROP.
I have 2' Drop Spindles & 2" Lowering Springs installed.
Truck will have a stock 350 crate engine and 700R4 transmission in it.
I already relocated the rear shocks just need to know if the front needs to be done as well.
If so, which kit should I buy??
CPP sells a relocation kit for around $50 but the description does not mention 60-66 C10 trucks.
Thanks for your help
Pics are welcomed
1BAD65 is offline   Reply With Quote
Old 01-22-2019, 11:59 PM   #2
kdad
Re: >> Front Shock Relocators for 60-66c10 with 4/6 DROP???<<
I made my own out of some heavy wall square tubing. moved the mount which gave me approx. 3" extra on the frame which is way more than I needed at the arm. I have a static drop of approx. 4"
Pics are in my build thread.
Scott
Pics are welcomed
Check out my build here http://67-72chevytrucks.com/vboard/s...d.php?t=768039
She may not be the prom queen but at least she puts out..
kdad is offline   Reply With Quote
Old 01-23-2019, 12:05 AM   #3
damnyankee36
damnyankee36's Avatar
For reference, I am using 2 1/2" drop spindles, stock suspension, 26.5" tall tires and bags on my 66. Not sure of the drop but the front cross member is about 3" off the ground on modified bump stops.
With stock location shock mounts, Monroe 37049's fit but are right at their compressed limit fully dropped. However, a hard hit would probably damage the shocks. My configuration has no room for error.
damnyankee36 is offline   Reply With Quote
Old 01-23-2019, 11:22 AM   #4
1BAD65
Thanks for the info Kdad- I will be looking through your build page
Old 01-23-2019, 11:24 AM   #5
1BAD65
Thanks for help, looks like I'm gonna go ahead and do the shock relocation mod for the front after all. After sleepin' on it, it makes sense to give the shocks a little more travel length.
Thanks again
Old 01-23-2019, 11:35 AM   #6
kdad
Sorry about the bad pics but you get the idea
You can bolt them on as others have done. I welded mine!
Old 01-23-2019, 12:05 PM   #7
Hack_Attack
Hack_Attack's Avatar
Had to stand in my neighbor's yard to see THOSE photos.
Hack_Attack is offline   Reply With Quote
Old 01-23-2019, 12:11 PM   #8
1BAD65
@KDAD Thanks for the pics !!
Your build thread is awesome, allot of work! You have some serious skills !!
Old 01-23-2019, 11:58 PM   #9
kdad
LOL... when your as old as I am, anything that you can get large is a great day...
1Bad ……… Always happy to help.
Old 01-24-2019, 06:28 PM   #10
damnyankee36
I like that kdad. I should consider doing that. It's an easy mod.
I only plan on running on the bump stops during parades etc., but if I were to bottom out when at ride height, (a couple inches higher), I might regret not adding extenders.
Hmmm...
Old 01-25-2019, 01:54 PM   #11
1BAD65
Thanks again to everyone for helping out
