Passenger car pitman arm on truck box?
It just hit me, I have a 49-54 pitman arm from a car, is it possible it could fit on the truck box? It's a lot shorter, that would be friggin awesome!
Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
Re: Passenger car pitman arm on truck box?
Well, this is interesting, I just tried it and it fits on the truck box! So now, I will have to see if it can work when I get the dropped axle, it sure seems like it would be the right length!
Brian
Yep, makes me go hmmmmmmmm
Brian
That was an old trick we used on Model A's - shorten the pitman arm for easier steering.
1951 Chevy Panel Truck Last edited by MiraclePieCo; 01-24-2019 at 04:24 AM. |
![]() Join Date: May 2015
I would think the shorter it is ,the slower it would be ....theres more speed at the longer length....
shorter arms shorten the steering radius making the steering react faster. could make the steering real twitchy. brian - why do you want to use a shorter arm? the stock one works fine with a dropped axle.
You get bump steer if drag link is at an angle.
Brian
![]() Join Date: May 2010
That shorter arm will probably make the steering easier but it's going to be slower too.
![]() Join Date: Jul 2007
He is trying to cut down on bump steer when he installs the dropped axle but it will shorten the turning radius a considerable amount.
That might be a slick mod for my OT roadster as I plan to use a left over AD box on it along with a 41/54 Chevy truck axle and springs and the turning radius may not be as big of an issue on it. Plus I have the parts.
with my 3" dropped axle and the stock arm, ive got no bump steer.
#11 | |
Brian
Yeah, I edited that to "easier" which is what I meant to say. Anyway, shortening the pitman arm was a common modification when I was into Model A's. I wonder how many A's are out there with welded pitman arms - yikes.
1951 Chevy Panel Truck |
| Bookmarks |
