![]() Join Date: Jan 2018
Fan Removal
I am trying to come up with a clever way to remove the fan for the swap without having to put the accessory drive on to c-clamp the belt. Any ideas on this?
Is it fairly easy to slide the motor in with the fan/clutch left on?
My Daily Driver Build: http://67-72chevytrucks.com/vboard/s...d.php?t=755668 |
Post Whore
![]() ![]() Join Date: May 2015
Re: Fan Removal
If you have a strap wrench thatll fit the pulley ,that would work....
As far as installing with the fan on it just depends on how much of the front end is on the truck...if it's all still intact itd be easier to do without the fan in the way....
#3 | |
Re: Fan Removal
As easy as it is to pull the fan, I wouldn't want to risk bending a blade while hanging a motor over the core support. |
Re: Fan Removal
hammer and chisel or large punch, smack the edge of one of the sides of what would be the large nut. i've done it over a hundred times
Re: Fan Removal
#6 | |
Re: Fan Removal
for anyone interested most of the tool trucks sell a fan tool that goes on the end of an ait hammer, they work well if you dont mind spending the coin or are worried about taking a punch or air hammer to the fan nut. |
Re: Fan Removal
Interesting, I will try all of the above posts and see what works the best or first.
#8 | |
Re: Fan Removal
![]() Last edited by kazoocruiser; 01-24-2019 at 12:46 PM. Reason: grammer school proofreading |
