Old 01-23-2019, 11:43 PM   #1
KMAT
1970 C10 front disc brakes
Someone told me I had to have two lines coming out of my proportioning valve to each front disc brake is that true help please. I have a 1967 C10 that I am converting over to power brakes and discs in the front
KMAT is offline   Reply With Quote
Old 01-23-2019, 11:53 PM   #2
Redneck Rydes
Redneck Rydes's Avatar
Re: 1970 C10 front disc brakes
You will need a disc/drum proportioning valve,and will have to fab up some lines
Redneck Rydes is offline   Reply With Quote
Old 01-24-2019, 05:02 AM   #3
GMCPaul
""two lines coming out of my proportioning valve to each front disc brake ""
The above statement is incorrect.
Currently you have a Drum Brake Line Distribution Block under your master cylinder and 1 front brake line and 1 rear brake line connect to it. The distribution block will be removed and replaced with a disc / drum proportioning valve and the same front brake line and same rear brake line will connect to prop valve although you will need AN adapters to adapt fitting size. You will not need to run 2 separate front brake lines for the front disc conversion. Your conversion kit should include 2 front brake hoses for calipers that then connect to original front brake lines where drum brake hoses connected.
Paul Sr @ GMCPauls
GMCPaul is offline   Reply With Quote
