High Pressure Power Steering Help
Hello,
I'm putting an LQ4 with hydroboost in my 72 GMC. I cut the bottom metric fitting off the high pressure hose that runs from the booster to the gear box. But, I having a tough time finding a steel 3/8 tube 7/16 tube nut. After doing a ton of research, I just ordered a brass one off of amazon (Dorman 785-293). But, I would rather have the steel one. Does anyone have any suggestions outside of buying a new 1972 hose and cutting the fitting off? Thanks, Stanley |
Re: High Pressure Power Steering Help
DO NOT use a brass compression fitting on the high pressure side of your power steering. You should be able to get ones from any hydralic hose shop that are rated for the pressure. Or you could just have them make an entire hose for you to order, which is what i would reccomend.
#3 | |
![]() Join Date: Jul 2009
I've never dealt with these folks, but I think this is what you want... https://hosewarehouse.com/105x6x7-tube-nut-steel |
#4 | |
#5 | |
meowMEOWmeowMEOW
Edelmann makes adapter stubs on hardline that can be installed with a flare.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
#7 | |
However, if it makes you feel better, it's fine to use a brass tube nut. The tube nut is not the same thing as a compression fitting that you are getting warned about. And, of course, the possibility exists that I'm just horribly confused over what you want.
#9 | |
http://67-72chevytrucks.com/vboard/s...d.php?t=523502 |
#10 | |
#11 | |
I live in Denver, but my wife is from Huntsville. Maybe we can hook up and I'll buy you a beer or lunch. In case anyone else has the same research issues and for historical thread purposes: https://www.napaonline.com/en/p/GATG605960607 https://www.napaonline.com/en/p/WH_105X6X7 |
![]() Join Date: Feb 2014
I’m running Hydro boost on my truck but I have not bought my lines yet what lines are you running
#13 |
@nsb29 I have the lines that come from my donor truck. That's why I needed to cut the line and convert to the SAE fitting at the gear box. Several people recommended going to the local hydraulic shop. But, I didn't want to spend that kind of money. If you need help, I'll try. If not, someone else will chime in.
#14 |
![]() Join Date: May 2015
I used stock hoses on my c30....I'm thinking about using -6an stainless braid on my IH and build my own....
#15 | |
#16 |
meowMEOWmeowMEOW
FWIW about the Edelmann stubs I mentioned; I don't have a link, but found them by requesting to look at the paper catalog for Napa Power Steering at the store.
#17 |
My donor truck was a 2003 2500HD. It'll look stock as heck.
#18 |
#19 |
![]() Join Date: Sep 2005
i just changed the nut on the back of the power steering pump to the one off the 71 pump and just used the stock 1971 c10 flare line
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2015 toyota Tacoma Daily 2012 Subura outback 2000 Tahoe 5.3l 420k 1999 honda accord General manager for Marco's Carwash & lube |
#20 |
@nsb29 I’m going to try to attach a few photos of everyting finger right.
#21 |
Well, they’re sideways... but, they’re there.
#22 |
#23 |
Dont mind my comment i jsut saw ti was hyrdoboost mine isn;t
#24 |
I used lines off of a 96, they fit pretty good and look stock. I also used a newer steering box so it's the 3 1/2 turn lock to lock rather than the old 4 1/2 turn one which also uses metric O ring fittings fo didnt have to reflare the lines any at all.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
#25 |
Not sure if any of this will help...I used a early 80s hydroboost...a steering box from 88 2wd truck....and a 2003 5.3.....all fittings are o-ring metric...16mm and 18mm threads.....I used a set of hydroboost lines for a 81...fit was great...looks stock..they had to order the other return line so that's why it's not installed in the pic..
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 02-02-2019 at 03:40 PM. |
| Bookmarks |
