Old 01-26-2019, 07:32 PM   #1
NJM73
Junior Member
NJM73's Avatar
Need help with updating brake master cylinder
I want to put a newer brake master on my 85 1 ton. Looking for one with a screw on lid plastic reservoir style. Reason being is that I am tired of going through gaskets and tension springs on my master. I keep the fluid level low too hut nothing seems to be a permanent fix.
Truck has hydroboost
Just tried early 2000s vac and hydro masters but both had bore too big to fit into the hydrobooster. The 90s chevy ones dont look like they would be much better than what I have now.
Wondering if there is another application that would have a master with a smaller case bore diameter. Trying to stay Chevrolet since everyone else went to metric fittings off the masters
'71 chevy suburban -all purpose rig- in progress
'93 cherokee -dd- mild wheeler
'65 chevy c30 c&c 12' flatbed -farm truck - future tow rig
NJM73 is offline   Reply With Quote
Old 01-27-2019, 02:52 PM   #2
hatzie
Moderator
hatzie's Avatar
Re: Need help with updating brake master cylinder
The GMT800 and newer master cylinder reservoirs make pressure bleeding the brakes a breeze. That three cam cap system would be very nice to have on the older trucks.
The GMT800 has Disc/Disc brakes vs your Disc/Drum brakes so the Master Cylinder bores will be biased differently from the squarebody and T400 master cylinders.
As you discovered, the tail of the T800 master cylinder is larger too... You may be able to just fit the Hydroboost and MC from a GMT800 with JD5 or JB5 or JD7 or whatever RPO HD brakes you have but that won't cure the differing bias...
If you swap in the AAM axle from the same GMT800 that'll get you close enough that it'll work... You get to re-cable the E-brake with the AAM swap along with moving the spring perches and shock mounts and any needed brake line changes.
Kindof a slippery slope.
Can you fit the plastic GMT800 reserviour onto an RV30 series Master Cylinder with the big square plastic reserviour that's setup for the same RPO brakes you have?
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 01-27-2019, 09:26 PM   #3
69heavychevy
69heavychevy's Avatar
I went through this same issue when swapping over to hydroboost. I wanted to use an aluminum MC with the plastic reservoir. Mostly for the ease of keeping an eye on brake fluid level and avoiding the rusty look of the original cast iron MC.
The piston bore on the various aluminum MC were all too large to mount into the HB unit. So I just ended up going with the cast iron MC unit it called for.
The GMT400 HB units mount up perfectly but the issue is the pedal rod is different. Those units do use an aluminum MC, they're essentially identical with minor external differences. I'm sure a newer HB unit can be made to work fine on these trucks, but I just didn't feel comfortable experimenting with my brakes.
80 C10 SWB Step Side - 350 w/ vortec heads, TH350, 12-bolt 3.73
69heavychevy is offline   Reply With Quote
Old 01-28-2019, 01:54 AM   #4
Big Moose
Installed a HB out of a 2005 2500HD on our 85 1 ton but had to modify the rod that connects to the brake pedal, had to lengthen it. also tried to install the MC with the plastic reservoir as well, but it was too tall, not enough room for closing the hood. so had to put the old MC back on.
Big Moose is offline   Reply With Quote
