Old 01-26-2019, 09:28 PM   #1
Big70
Driveline issues
OK I’m going from a small block 350 long wheel Bass to a 454 in the same truck so we tried to put the driveline in and obviously I knew the motor had moved back we could almost get it all the way in but there will be no space for the yoke to go inside of the tranny so I’m going to cut the driveline down in the front portion of it in front of the carrier bearing so my question is how much gap should I have between the tail shaft of my tranny and the Botom of the yoke I was thinking about cutting off 1 1/2 inch
Big70 is offline   Reply With Quote
Old 01-26-2019, 10:31 PM   #2
kazoocruiser
Re: Driveline issues
Put the truck on a liftback, take it and the driveshaft to the shop that is going to do the work, and let them sort it out. You can do what you want, but I think you will be happier with the results if you let the ones who do that kind of work make the "measure twice, cut once" assessment.
kazoocruiser is offline   Reply With Quote
Old 01-26-2019, 10:55 PM   #3
Sheepdip
Sheepdip's Avatar
Unless you have some way to balance it your pissing in the wind my friend.
Sheepdip is offline   Reply With Quote
Old 01-26-2019, 11:25 PM   #4
Big70
It’s going to be cut by my drive line shop for sure but can’t take the truck there just was wanting to know if any one knows how much of the yoke should I be able to see out the back of the tail shave cause I know there is suppose to be wiggle room just thought some one on here might know how much....
Old 01-26-2019, 11:35 PM   #5
LockDoc
The Older Generation
LockDoc's Avatar
I have always inserted the yoke as far as it would go and pulled it back out 3/4-1", then measured the length for the shaft. That has always worked for me. Make sure the splines inside the yoke are clean all the way down.
LockDoc
Leon
Old 01-26-2019, 11:37 PM   #6
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Call the driveline shop that's doing the work and ask them what measurements you should take. This isn't an area you want to guesstimate or wing-it.
When I had a custom 1 piece driveline made for a 1979 K25 I had, the guy at the driveline shop talked to me on the phone while I was crawling under the truck with a tape measure.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 01-27-2019, 10:11 AM   #7
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Driveline issues
Just had all this answered on another site and the answer is as stated push it all the way in to the transmission and then pull it out 3/4" to 1" and mark it. Then have it cut to fit.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 01-27-2019, 05:53 PM   #8
Big70
Just curious because I am going to go to a short bed does the factory short beds have a two-piece driveline with the carrier bearing?
Old 01-27-2019, 07:07 PM   #9
Andy4639
Old member
Andy4639's Avatar
From what I have seen and herd yes some did some didn't.
When I did the 6.0 LS with 4L80E swap I got a 1 piece for my LWB truck installed.
Old 01-28-2019, 12:55 AM   #10
Steeveedee
Who Changed This?
Steeveedee's Avatar
LockDoc
This is the answer, right here.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
