E brake cable and wide wheels????
Won't to run a wider wheel on the rear but what a bout the e brake cable? How much off set to the rear can I run be for interfearing with the cable?
OLDIRONRACING |
Post Whore
![]() ![]() Join Date: May 2015
Re: E brake cable and wide wheels????
Can you not measure from your current tire to the cable and then add that to your current rim offset.?..then subtract a inch or so....
Other than that it's just a guess since I dont know what axle, tire, wheel,vehicle..etc etc that you have
x2. What works for one set-up might not work for another (as a general rule).
