Old 01-27-2019, 05:51 PM   #1
Streetglide2015
Thrift-Air Heater issues... '64 C10
Could this be a resistor problem? Need your expert advice...
I keep replacing fuses in the block, for the heater. The switch seems to work fine (all three fan speeds) each time I replace a fuse. HOWEVER, the fan seems to blow fuses when I rev the engine a bit, and the speed of the fan increases with acceleration.
Based on some of the things I have read about the Thrift-Air system, it sounds like a bad resistor (?) There seems to be no other electrical issues with this '64 C10, but could it also be a voltage regulator causing this?
I know enough to be dangerous, about electrical issues... Any advice or opinions are welcome! Thanks!
Streetglide2015 is offline   Reply With Quote
Old 01-28-2019, 01:43 PM   #2
Streetglide2015
Re: Thrift-Air Heater issues... '64 C10
With all the expertise and experience on this board, I'm surprised that I have had no replies to my question. Anybody??
Old 01-28-2019, 01:54 PM   #3
61K10
61K10's Avatar
Nothing to test with? No volt meter? Run a wire from the fuse block to the fan motor by-passing the resister and switch and see if it blows the fuse. Go buy a cheap volt meter.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 01-28-2019, 02:51 PM   #4
Streetglide2015
Makes sense... Thanks!
Old 01-28-2019, 04:02 PM   #5
shp4man
shp4man's Avatar
Without any testing, which is the correct way to diagnose this, I would say unplug the blower motor, replace the fuse, move the fan switch around as you rev it and see if it blows.
If not , 75% chance it's the blower motor.
What size fuse are you using? How many amps? Factory wiring or aftermarket?
Everybody has to believe in something. I believe I'll have another beer.
shp4man is offline   Reply With Quote
Old 01-28-2019, 04:09 PM   #6
Streetglide2015
It seems to blow the fuse when the switch is on High (but it may have done it on the lower settings also). A 10-amp fuse is what's required, and is what I'm replacing each time. Everything is original GM, no aftermarket, and apparently original. The good thing is that fan motors aren't very expensive to replace if that's the issue.
Thanks!
Old 01-28-2019, 04:56 PM   #7
straight6chevyguy
straight6chevyguy's Avatar
I would all so check all the wires going to the switch and all the wires to the resistor and the wire to the fan make shore that none are cracked and shorting out on any thing under
the dash.
All so if you have not all ready, check out the resistor.
the one in my truck was falling apart. (careful, I don't know what there made out of mine looked like it was asbestos but I don't know)
Like some others said it may be the fan motor take the motor out and see if it spins
freely, if not it could be causing the problem.
1965 chevy c20 292 4speed http://67-72chevytrucks.com/vboard/s...d.php?t=777601
1976 chevy c10 250 4speed http://www.67-72chevytrucks.com/vboa...d.php?t=787037
1978 chevy c20 350 4speed
1998 chevy c1500 4.3L 5speed
2002 Chevy s10 4.3L auto 4x4
Plus a Mercury & some Fords... To many projects!
straight6chevyguy is offline   Reply With Quote
Old 01-28-2019, 09:29 PM   #8
Streetglide2015
Thanks for the info everyone!
