Old 01-27-2019, 09:40 PM   #1
Wyattdog2
ls intake is tight
anybody doing a ls with a code 504 kit and have suggestion for the air cleaner ? seems like it is very tight. Not sure how to add pic from my phone
Wyattdog2 is offline   Reply With Quote
Old 01-27-2019, 10:09 PM   #2
mongocanfly
mongocanfly's Avatar
Re: ls intake is tight
Any pics?...
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 01-30-2019, 11:18 AM   #3
jweb
jweb's Avatar
A pic would really help. I don't have the 504 kit but my intake was a tight fit to the radiator. So I ordered a short radius intake hose like this
https://www.intakehoses.com/rubber-e...rt-radius.html
1951 Truck, LS1/4L60
1964 Suburban, current project
jweb is offline   Reply With Quote
Old 01-30-2019, 01:24 PM   #4
DaveNY
Mine is also super tight, I used one from spectre
https://www.jegs.com/i/Spectre/865/9781/10002/-1
DaveNY is offline   Reply With Quote
Old 01-30-2019, 03:43 PM   #5
mr48chev
mr48chev's Avatar
I'm thinking that is a that style of Fi Issue that every one on here who runs one no matter what the chassis is deals with. You look though the photos of trucks with this fi setup and you see nearly as many different setups for filters and air intakes as you see trucks.
My ongoing truck projects:
Old 01-30-2019, 04:18 PM   #6
jweb
jweb's Avatar
Here's a pic of the tight 90 hose. I have added a fan shroud since so it's actually a little closer now.
Old 01-30-2019, 10:01 PM   #7
Wyattdog2
dang, nice job there. i ordered a sharp 90 and will go from there.what fan are you using? hanks for the pic
Old 01-31-2019, 03:05 AM   #8
Advanced Design
Advanced Design's Avatar
Dave, thanks for the share on this as it may solve my clearance issue too.
Advanced Design is offline   Reply With Quote
Old 01-31-2019, 11:06 AM   #9
jweb
jweb's Avatar
I used a SPAL low profile, I think this is it:
https://www.jegs.com/i/SPAL/063/30100401/10002/-1
I guess I should also mention I cut the top off my core support and moved the radiator forward. Still need to make a new bolt on top, but I'm busy with several other projects right now.
Old 01-31-2019, 11:43 AM   #10
clegg
Very nice overall install. What did you use to trim out where the intake runs through the inner fender?
clegg is offline   Reply With Quote
Old 01-31-2019, 01:52 PM   #11
jweb
jweb's Avatar
That's just black pinch welt. Should be able to get some at any auto upholstery shop.
My filter is in front of the tire in a custom built box. Then I cut a hole in the front of the inner fender (behind the grill) for air. This probably wouldn't work well for a truck that's really low. There's not a lot of room form my tire to the filter box.
