Old 11-23-2003, 08:57 PM   #1
sledge_hammer
Unhappy 72 rear leaf lowering
Hi guys,
Lowering my 72 C10, s/b, s/s that has rear leafs. The truck was a 6 cyl 3 spd prior to change over. Wanting guidance on how to lower the rear. Installing a western classic 2 1/2 spindles on the front, and wanting to lower the back 4-5". And are there options on removing the leafs, and going to a ladder bar set up?
Powered by 68 Chevelle 396, 30 over, T-400.
Also, what size wheel and tire combo is recomended, that is the same front and rear. If you are giving sizes, please include off set.
thanks
sledge_hammer
from southern bc
PS referred here by longhorn man (chevy talk)
72 C10 s/b s/s 396 T400
sledge_hammer is offline   Reply With Quote
Old 11-23-2003, 09:11 PM   #2
dinnut
dinnut's Avatar
im sure somebody sells drop leafs. do you like that chevelle engine? 20s are awesome if you can afford some nice ones
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 11-23-2003, 10:30 PM   #3
gr8scott51
gr8scott51's Avatar
flip it
I've got a friend with a '70 w/leafs pondering the same thing. He says a flip kit from Classic Performance Products (www.classicperform.com) or similar will drop the rear 5 or 6 inches. I think early classic enterprises, no limit have similar. You might try WES at Classic Heartbeat in Olympia, WA. A run for the border might save you some coin.
good luck, scott
Silence is golden, duct tape is silver. - Scott
gr8scott51 is offline   Reply With Quote
Old 11-24-2003, 12:58 AM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
sledge_hammer, glad to see you made it over here.
gr8scott51...does that kit require a c-notch in the frame rail?
Old 11-24-2003, 01:07 AM   #5
72shadetree
KEEP ON TRUCKING
72shadetree's Avatar
andy i dont think you need a c notch.the rear is mounted under springs just move it on top
72 cheyenne 2wd lwb
71 k20 sons
bassett va
72shadetree is offline   Reply With Quote
Old 11-24-2003, 01:23 AM   #6
Longhorn Man
True, but I know on other model trucks, just flipping it requires a C-notch or a set of lifting shackles.
Old 11-24-2003, 01:55 AM   #7
67cst
i love summertime
67cst's Avatar
hey sledge-got any pics? maybe ive seen your truck around, im from kelowna but down in pen lots cause my dad lives in summerland
1967 shortbox stepside Chevy, 365 hp 327, th400.
GLOVE BOX LIGHTS FORSALE, click link for info
http://67-72chevytrucks.com/vboard/s...d.php?t=273724
67cst is offline   Reply With Quote
Old 11-24-2003, 01:56 AM   #8
gr8scott51
gr8scott51's Avatar
nope
From the "how to" on the CPP or ECE sites, no mod to the frame is required.
Scott
Oh yeah, wheel size. Should be able to find threads on this using search, but 15 x 8s with 4-1/2" backspace is normal.
Old 11-24-2003, 02:34 AM   #9
jorgensensc
jorgensensc's Avatar
I had a flip kit on an '82 C10 and honestly it rode horrible!!! If you do the flip kit, be sure and get the lowered shocks, or you will go through them like gum
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 11-24-2003, 02:43 AM   #10
krue
Designated A-hole!
krue's Avatar
Welcome to the board from South Mississippi!
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 11-24-2003, 12:47 PM   #11
Ackattack
Ackattack's Avatar
I took out a leaf on my truck to lower it. It seems to ride fine. Though I plan on making some sort of anti axle wrap/traction bars in the future.
As for wheels , right now I'm running 15x8 with 245/60/15s on the front and 15x10 with 295/50/15s on the back.
Ackattack is offline   Reply With Quote
Old 11-24-2003, 04:02 PM   #12
72MARIO
72MARIO's Avatar
I have a 72 Shorty leaf truck. I used a 2" western drop sackle. And I went to a spring shop and had the rear springs darched 3" I have a 2.5" spindle and a 1" spring. There is no motor or tranny in it yet so I dont know exactly how it will sit. I don't suggest removing any springs excepy if you have aover load spring. that wil give you about 1". Classic Performance Products also sell's drop springs for the rear if you are into spending alot of money.
Later Mario
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 11-24-2003, 08:55 PM   #13
slogo
slogo's Avatar
I have a set of CPP 5.5in drop springs that i will sell never used. and you will need a C-notch. pm me if i can help you.
slogo is offline   Reply With Quote
Old 11-25-2003, 12:25 AM   #14
sledge_hammer
slogo
Thanks for the offer Slogo, that drop would be too much, I am running full headers and they would interfer with clearance with that much drop. Thanks anyway.
Old 11-25-2003, 02:00 AM   #15
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Welcome to the board from southern oregon ... I would go with the flip kit and a c-notch... I have also heard of somehow flipping the rear schackle..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
