Old 01-28-2019, 11:44 AM   #1
raic65
raic65's Avatar
66 c10 LWB fleetside bed dimensions
Hi everyone. I tried to look but didn't have any luck. I am assembling a new bed for my C10 and can't find dimensions for how far apart the bedsides should be and where are good places to measure from. I am using all aftermarket parts with the exception of the floor. I'm using a used 67-72 steel bed floor. Appreciate any help I can get.
Robert
raic65 is offline   Reply With Quote
Old 01-28-2019, 05:42 PM   #2
jayoldschool
Moderator
Re: 66 c10 LWB fleetside bed dimensions
Your front panel and your rear cross member will dictate how far apart the bedsides are. Once it is together, you may need to pull the tops of the end of the bedsides together a bit. This amount will depend on the tailgate. Measurements won't really help with any assembly, you just have to put it together, and tweak where you need to.
We built this bed from all new parts.
Truck turned out nice!
jayoldschool is offline   Reply With Quote
Old 01-28-2019, 06:51 PM   #3
62bagger
62bagger's Avatar
That is really nice. great work.
62bagger is offline   Reply With Quote
Old 01-28-2019, 06:58 PM   #4
jayoldschool
Moderator
It actually had no bed, it was a factory flat bed C20. No bed supports. So, I just made cardboard templates from my C10, and bent them up on the brake.
Old 01-29-2019, 02:03 PM   #5
raic65
raic65's Avatar
Looks like I will need to get a tailgate. Thanks for the suggestion.
