Old 01-28-2019, 10:40 PM   #1
mygmctruck1
Gage cluster lens seal
I am in the process of reassembling my gauge cluster. In my new parts I have a seal that goes between the lens and a gauge. I am guessing it’s for the speedo gauge , which also help get it snug to the mounting tin.
Or is there some where else it goes ?
mygmctruck1 is offline   Reply With Quote
Old 01-28-2019, 11:06 PM   #2
Andy4639
Old member
Andy4639's Avatar
Talking Re: Gage cluster lens seal
I know of any gauge cluster for 67-72 that has a seal none.
The lens have the little sponge pieces about a inch long that should go around all the plastic in spots though.
Are you talking about item #10? If so you cut it to fit in the slots in the plastic face on the inside where the lens will lay. If you lay the cluster face down you will see small slots around the outside of the gauges this is where the pieces go. Cut it to fit each one.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 01-29-2019, 09:38 AM   #3
mygmctruck1
Got it , thanks
