3 spd shift linkages??
I’m in search of 3 speed on the column linkages to the trans 1970 with 307 and I’m pretty sure 7 bolt side cover saginaw. Can anyone tell if these are the links I need? Thanks
Posted via Mobile Device |
![]() Join Date: Mar 2017
Re: 3 spd shift linkages??
You need to know for sure if it is a seven bolt. They are different from the four bolt.
I'm actually looking for the same parts for a four bolt M18/19 to complete my overdrive conversion.
72 C20 292 3OTT 77 GMC 2500 4x4 Longstepper 350 4sp 50 3100 ex Airforce/Town of Mendon fire truck 72 GMC 1500 2wd short stepside 250 4sp 78 GMC 2500 4x Longstepper 292 4sp 54 6400 Chevy 5 window 4 sp 2sp vac rear end Shell oil truck/dump truck (Norman) |
I have a pair of those for that application at the house. Unfortunately I'll be away for a couple weeks before I can take a look and post some pictures. If no one else post them first I'll get back with you as soon as I can.
Steve weim55 Colorado |
I have a bunch of those linkage arms but I don't know what is what myself. I believe the only difference is 6cyl vs V8 and which transmission. I am thinking the 6cyl arms will be the longer ones, since the transmission sits farther back in an inline-6. I also have a 3spd transmission or two. I'd have to look to see which one. If someone could measure theirs it would help us all.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 01-30-2019 at 07:07 PM. |
I just tried to get a measurement on the linkage arms on my 72 c20 with a 292. I couldn't get an accurate one. What I could get is the measurement from the bellhousing to the center of the holes in the shift levers on the transmission.
On the seven bolt, when both levers are in neutral, the center of the hole in the 2nd/3rd lever is less than an inch. Also the shift arm that connects to this lever has a "J" curve at the end as it hooks around the clutch boot. The 1st/2nd lever is 6 1/2 inches from the bell housing. On the four bolt, the center of the holes on the levers are 2 1/2 and 3 1/2 inches from the bellhousing. If the weather warms up next week. I can take them off and measure them better. The pictures are to show what that "J" curve looks like. Also, I'm looking for the arms for the 4 bolt
72 C20 292 3OTT 77 GMC 2500 4x4 Longstepper 350 4sp 50 3100 ex Airforce/Town of Mendon fire truck 72 GMC 1500 2wd short stepside 250 4sp 78 GMC 2500 4x Longstepper 292 4sp 54 6400 Chevy 5 window 4 sp 2sp vac rear end Shell oil truck/dump truck (Norman) Last edited by NewBayColony; 01-31-2019 at 07:39 PM. |
Looking at the EBay picture now, I think these are 4 bolt arms as neither has the "J" hook.
72 C20 292 3OTT 77 GMC 2500 4x4 Longstepper 350 4sp 50 3100 ex Airforce/Town of Mendon fire truck 72 GMC 1500 2wd short stepside 250 4sp 78 GMC 2500 4x Longstepper 292 4sp 54 6400 Chevy 5 window 4 sp 2sp vac rear end Shell oil truck/dump truck (Norman) Last edited by NewBayColony; 01-31-2019 at 07:38 PM. |
69 GMC, did you ever find the linkage you were looking for? I'm gonna start looking for a set for my m18/m19 4 bolt sidecover trans now and I was wondering if you had any success.
72 C20 292 3OTT 77 GMC 2500 4x4 Longstepper 350 4sp 50 3100 ex Airforce/Town of Mendon fire truck 72 GMC 1500 2wd short stepside 250 4sp 78 GMC 2500 4x Longstepper 292 4sp 54 6400 Chevy 5 window 4 sp 2sp vac rear end Shell oil truck/dump truck (Norman) Last edited by NewBayColony; 02-19-2019 at 08:54 PM. |
Better Picture of both linkage ends at transmission. (7 Bolt)
#9 | |
This is my side cover. Btw.. what’s the thing sticking down off the 2/3 linkage hole?
I found a set a guy here close to me had. I seen them still on the truck. V8, and 7 bolt side cover trans. I got them and got home and they dont work for mine. Too long. They look like the ones that you posted. Even got the small linkage ends with the different indexed holes for at the transmission. I started to think maybe the 307 was supposed to be in the rear motor mount holes, but that can’t be because the bellhousing mount wouldn’t line up at the crossmember. I’m stuck and don’t know where to go from here??
This is the last set I got that I just knew was gonna work
#13 |
I can get mine out and take pictures for comparison
#14 |
I still am looking for set from a 67/68 with a light duty Muncie 4 bolt side cover. I might have to make a set.
#15 |
#16 | |
Do a search in the above "Search" box to find even more links explaining it.
#17 | |
#18 | |
#19 | |
#20 | |
#21 |
If the rods you are using came from a truck that originally had a six cylinder the ears for the transmission linkage Will be in a different position about 4 inches back from that of an original V-8 application. If you look at The frame on your truck you'll see another set of Bell housing crossmember holes about 4 inches behind where your current crossmember is riveted to the frame. That crossmember is different six cylinder versus V8 although they look very close to the same.
A couple things to look for on the parts truck: look to see if the distributor cap is right on the firewall, about an inch away? Yes = likely an original six cylinder truck. Look at the Vin number for the truck, if the second digit is an S = six cylinder , E = V-8. You'll notice on your truck the distributor cap is a good 4 inches away from the firewall, Big difference. I mentioned earlier I would try to get pictures to you of the correct linkage. I've had some health issues that have kept me away from the house for a while but is soon as I can get my eyes on it I'll get those to the thread. Steve weim55 Colorado |
#22 |
![]() Join Date: Dec 2013
I converted my 6 to V8 and changed the manual trans cross member to the correct V8 one that mounts further forward in the frame than the 6 cross member does . you can see the V8 is a little heavier and has a different angle to fit the frame . Just look at the engine perches to see what hole they are in .
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
#23 |
Gotcha. Didn’t think about the trans crossmember having a mount farther back as well. So if that’s the case and this V8 is in it, like you say it’ll be in the rear mount position in order to bolt to the bellhousing?
#24 |
Yep , and the 6 trans linkage should fit .
#25 |
Looking at this pic I took when I was removing the linkages, there seems to be quite a bit of room to see daylight between the bellhousing and firewall.
