Old 11-23-2003, 09:20 PM   #1
rage'nrat638
rage'nrat638's Avatar
Question Reverse Light Problem...electrical
OK...I DON'T THINK I AM STUPID???
reverse lights did not work.....tested light socket...no power in reverse....
replaced neutral/reverse switch...WHAT A PAIN...it was broken....
NOW GOT POWER TO REAR TAIL LIGHT CONNECTOR..female part.
plugged in male part.... flickers on and off (with test light)
when moved...
REPLACED COMPLETE CONNECTOR....
now got good power thru connector w/test light with shifter in reverse....
used 12 volt's to check lights (reverse) work fine...
hook the two light green wire's to the reverse lights...nothing...
thinks this is a bad ground on lights?????
lights drawing to much thru reverse switch????
truck junk get rid of it ?????
rage'nrat638 is offline   Reply With Quote
Old 11-23-2003, 09:28 PM   #2
dinnut
dinnut's Avatar
its junk. just junk it. in my yard. make sure you leave the keys and the title.
seriously. i dont know. mine dont work either. i got a crapyp floor shifter. ask somebody that knows?
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 11-23-2003, 09:30 PM   #3
67Fleetsidedream
Wiseass secured himself a BAN
67Fleetsidedream's Avatar
Are you using the right kind of light bulb?
67Fleetsidedream is offline   Reply With Quote
Old 11-23-2003, 09:33 PM   #4
rage'nrat638
1156 SINGLE ELEMENT....
thats what was there.....even tryed a smaller bulb...
NOTHING....
Old 11-23-2003, 09:38 PM   #5
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
You are talking about the 69 right...dark green wire goes to the passenger side prong and the light green one goes to the driver's side prong..Also should be 2 purple wire's for the neutral saftey switch... I also had to adjust my brake/saftey switch on my auto colume(sp). Do you have a manual or auto???
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 11-23-2003, 09:57 PM   #6
Chevy67Tk
Chevy67Tk's Avatar
I agree the truck is junk, just can’t be fixed, you might as well sell it to me for a $1.
But if you have some spare time I would check your grounds in your sockets, this would save me a lot of time when you deliver it to my house.
Chevy67Tk is offline   Reply With Quote
Old 11-23-2003, 11:16 PM   #7
jorgensensc
jorgensensc's Avatar
Who needs reverse lights!!???! Just back her right up
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 11-23-2003, 11:36 PM   #8
rage'nrat638
ok ...don't ask me why!!!!!!!!
just checked for power at the switch....GOT POWER
HOOKED UP A JUMPER....from the fuse box to the connector...
wire going to the reverse lights....
THEY WORK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!
CUT THE GREEN WIRE COMING FROM THE FUSE BOX.....
stock.....hooked it up to the switched fuse box open lug
EVERY THING WORKS....WHEN PUT INTO REVERSE
WTF.....only got about 6 hrs. invested into reverse lights...
GOING TO BE USING THIS TRUCK TO TOW WITH ..........NEED TO BE ABLE TO SEE TO BACK-UP AT NIGHT...........
Old 11-23-2003, 11:38 PM   #9
jorgensensc
Well fine... If you WANT to see... But now you have to use your mirrors, maybe even turn your head... too much trouble!! Ha HA
Old 11-24-2003, 02:41 AM   #10
krue
Designated A-hole!
krue's Avatar
That's why you keep a spotlight in your truck.
Honest Mr. Park Ranger/Game Warden the light is there because my back up lights don't work.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
