01-30-2019, 12:54 PM | #1 |
Spring compressor for front BBC front Coils
What spring compressor is needed to install the front heavy duty coils on a 72 C-10? My compressor will not work.
Thanks, Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
01-30-2019, 01:40 PM | #2 | |
Re: Spring compressor for front BBC front Coils
If your truck is otherwise built you shouldn't need a compressor. Use a floor jack under the lower control arm instead. I bought mine because it's just a frame, no weight. That said, I decided to wait until after the engine is installed and try to do without the compressor. Whatever you do secure the coil spring on install, such as a chain securing the coil to the control arm, for just in case.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
01-30-2019, 02:17 PM | #3 |
Tony, thanks for the reply! I will probably just wait until I get the BB in the frame. Right now the front end of just the frame is not heavy enough to work and my existing compressor will not fit through the hole in the lower a arm!
Jim
01-30-2019, 02:52 PM | #4 |
If you really want to get it done now... Autozone will let your borrow their tools: Coil spring compressor: https://www.autozone.com/loan-a-tool...ing-compressor Strut spring compressor: https://www.autozone.com/loan-a-tool...ing-compressor Either of those would work. One on the outside and the other on the inside. Basically you pay for the tool retail price ( deposit ) and then return it for a full refund when you're finished using it. BTW, these compressors scare the crap out of me! Especially the two piece type where you're tightening down two different bolts to compress the spring. That's only when you're installing new springs though. If you just want them out to do other work, the compression is already in the spring, the "compressor" is simply going to hold it there while you R&R the same spring. I typically remove the springs using the weight of the truck/car as mentioned. But I have used these to replace old springs with new. That's when things get sketchy/scary for me. Hth, -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
01-30-2019, 05:52 PM | #5 |
That is scary stuff compressing coil springs and installing in vehicle without a motor trans or front clip. I've done it before. Id wait or at least set something about 700 lbs on the front of the frame and do it like there is an engine.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
01-30-2019, 10:44 PM | #6 | |
I'm with you, I compressed my old spring an inch or so just to see. Takes some turns even an inch. Everything went smooth and square but NOPE, didn't like it one bit. That and the pain protecting the surface of the new one. I'm hoping I can slide them in cleanly with the weight of the engine and floor jack. If that's short then my 220 Lb. son can perch on top of the frame. If that's short it strikes me some blocks under the opposite frame rail may counter................um, something
02-04-2019, 12:53 PM | #7 |
Thanks for the suggestions. I have an internal spring compressor which works great on the SBC but if I install the tool then I cannot get it back out as the larger diameter coils don't leave enough room to maneuver the compressor out once the coil is compressed.
Jim
02-05-2019, 09:42 AM | #8 |
Yes you can borrow the parts from the parts house. I prefer the one with a fork.
I find it easier to unhook the lower A-arm at the cross member and use a jack to hold it back in place. Spring stays mostly unloaded doing this.
'72 3/4 Cheyenne Super 402/TH400 Gear Vendors '72 3/4 Cheyenne Super 350/200R4 '50 1/2 Chevy 3 Window |
02-05-2019, 11:43 AM | #9 |
I used an internal 2- or 3- arm that goes up the middle. Chain everything up and stay far away from it, and so not use an impact.
