Old 01-30-2019, 07:06 PM   #1
randy500
Frame cuts, 2wd 3/4 ton leaf spring, and dually 1 ton
$35-75 each plus shipping, price depends on how big you need. I have 2 rear frames. I also have a 68 1ton dually leaf spring frame.
randy500 is offline   Reply With Quote
Old 01-31-2019, 12:53 PM   #2
Speedracer39
Speedracer39's Avatar
Re: Frame cuts, 2wd 3/4 ton leaf spring, and dually 1 ton
I am looking for a pair of frame mounts for a 1/2 ton. These are the mounts that are riveted to frame that your leaf spring is mounted to my leaf is 2 1/4 wide is the 3/4 ton the same?
Speedracer39 is offline   Reply With Quote
Old 01-31-2019, 01:30 PM   #3
randy500
I will measure mine, I think the shape and mounting holes might be the same.
Old 01-31-2019, 02:13 PM   #4
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Still looking for some rear shock upper mounts.
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
D.PASSMORE is offline   Reply With Quote
Old 01-31-2019, 03:02 PM   #5
randy500
I think these 3/4 ton upper shock mounts might be the same, I will measure the frame height. What year is your frame?
Old 01-31-2019, 03:05 PM   #6
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Originally Posted by randy500 View Post
i think these 3/4 ton upper shock mounts might be the same, i will measure the frame height. What year is your frame?
1970 / borrowed picture
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
Old 01-31-2019, 07:18 PM   #7
randy500
My leaf springs are 2 1/4” wide the bushings are 2 5/8” wide so i believe mine are what you want. $85 shipped...it’s a lot of rivets to cut.
Old 01-31-2019, 07:22 PM   #8
randy500
Picture of what I have, the frame is about 4.125” inside dimension where these mount.
Old 01-31-2019, 07:26 PM   #9
randy500
I have multiple rear ends i could cut shock mounts from. These seeme to be the thickest ones.
Old 01-31-2019, 07:44 PM   #10
randy500
These are lighter duty metal and much easier for me to get at
Old 02-01-2019, 04:49 PM   #11
Speedracer39
If it looks like this I’ll take them —- just want to make sure and when you give me the thumbs up I’ll shoot you funds with pay pal
Old 02-01-2019, 05:27 PM   #12
randy500
I would say these are the same, rear mount
Old 02-01-2019, 05:31 PM   #13
randy500
Front, it’s wider at the top than at the the bottom
Old 02-01-2019, 08:12 PM   #14
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Let me look around for the correct ones Randy. Thanks man!
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
Old 02-01-2019, 08:20 PM   #15
randy500
Your welcome
Old 02-17-2019, 06:09 AM   #16
Madkidd007
Madkidd007's Avatar
So does this mean you still have these?
70 C10 highschool truck now C20 cummins powered
72 Crew Denali, Bigger, Stronger, Faster, well you get the point.....
the ole 65 continental
Syclone killer AWD T56 LS
Paypal please pay as Goods&Services Madkidd00000007@yahoo.com
Madkidd007 is offline   Reply With Quote
Old 02-17-2019, 12:00 PM   #17
randy500
Nobody bought any cuts from the pictures, what are you needing?
Old 02-17-2019, 05:14 PM   #18
Madkidd007
Madkidd007's Avatar
Well I seen the upper shock mounts for the rear while I was at work. But just measured my frame and I wasn’t thinking. This 157” chassis the rail is over 6” y’all back there. Maybe I could put a spacer in the lower side or do you have any upper shock mounts like the borrowed picture you posted?
Old 02-17-2019, 05:30 PM   #19
randy500
those are the only shock mounts I have.
Did yours come with shock mounts? I have a 68 C30 frame here and it doesn't have any shock mounts.
Old 02-17-2019, 05:50 PM   #20
Madkidd007
Madkidd007's Avatar
Mine did not. The ones you took the picture of with the triangular mounts. How much you want? I may could add another bracket and make them work, just a shock after all
Old 02-17-2019, 05:53 PM   #21
randy500
I agree that it’s a good start on a shock mount.
How about $45 shipped, cutting rivets sucks....
Old 02-17-2019, 08:19 PM   #22
Madkidd007
Madkidd007's Avatar
Payment sent
