11-23-2003, 10:09 PM | #1 |
Need good used 68-71 style big block motor mounts
Just like the title says. I need the motor mounts and all hardware. I have the towers. I would like to find used because I just don't see paying $150 for new ones. Any help would be great. Thanks jim
68 short fleet with 71 front clip 2wd jaguar blue 99 chevy ext cab shrtbed z71 loaded 99 chevy swb fleetside(daily driver) Sparks, Nevada |
11-23-2003, 10:26 PM | #2 |
KEEP ON TRUCKING
if you have the towers the mounts shoud be the same as a sb about $8 apiece at your local auto parts
72 cheyenne 2wd lwb 71 k20 sons bassett va |
11-23-2003, 11:21 PM | #3 |
Watch out for your cornhole !
Yep, small block mounts. For the rubber piece underneath the frame stand that the bolt runs through, I used an extra set of core support biscuits. Total cost of everything was about 35 bucks, new.
11-24-2003, 08:07 PM | #4 |
TTT
11-24-2003, 08:25 PM | #5 |
I guess mine and shadetree's answers aren't what you're looking for?
It worked great for my big block.
11-24-2003, 08:43 PM | #6 |
KEEP ON TRUCKING
sorry how i worded it wasnt trying to say that sb will work instead of bb.
the sb and bb use the same mount just different towers for 68-71 72 style was totlly different both mounts and towers the mounts new are around $8 apiece 2 needed the hardware i forget the size consist of 3 bolts each side to block and 1 on each side for mount to tower for a total of 8 short bolts 4 around $2 at hardware around $20 not $150
11-24-2003, 10:05 PM | #7 |
Thanks for the input. That's probably what I am going to end up doing I just thought I'd check to see if anybody had any laying around. Thanks JIM
11-24-2003, 10:10 PM | #8 |
TTT
11-24-2003, 10:14 PM | #9 |
Project Junkie! Fishing Poor!!
Small block and 68-71 BB motor mounts are not the same. You may be able to make it work, however the Big Block motor mounts are both larger and stronger. WES www.ClassicHeartbeat.com
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
11-24-2003, 10:34 PM | #10 |
Thanks Wes
11-24-2003, 10:43 PM | #11 |
Your welcome. WES www.ClassicHeartbeat.com
