11-23-2003, 10:14 PM | #1 |
Randy churchill
engine parts
I have a few parts for sale but need to be picked up.
edelbrock #1405 600 cfm manual choke carb used, comes with a rebuild kit and a Mr. Gasket adapter for a Q-jet intake. $150 dollars. A 307 crank with crane cam true roller timing chain set, and coneting rods, and pistons, harmonic blancer, also have a 68 307 block that needs to be taken to a machince shop. and if I can find it a "claimer short water pump. The crane cam and lifters where ruint because the oil pump qiute. $200 dollars. Have the stock 2 barrel intack with rodchester 2gc carb off the 307 $25 dollars. what was told are 327 powerpack heads but I haven't check the casting numbers. They need to be cleaned up cause they sat in my store room floor for two years, but they do have chrome valves and crane cam racing springs. I don't know what these are worth but I am open to any good offers I hate to see them go to waste. These where off the 307. I have a 81 350 out of a gmc 3/4 ton, less the heads everything eles is there. It has the stock bore and that is all I know on this motor, the previous owner had taken the truck to a performance shop and had work done to it. All I want for it is $300 dollars. I will make a package deal with the heads on either motor I will trade for parts for my 67, are stereo equipment. I am looking for a 67 floor shift column, straight hood and a/c parts.
1983 GMC K2500 6.2 diesel 4" lift on 35x12.50 tires 2008 GMC 2500HD 6.6 diesel 3" lift on 315 75 16X10 2003 Jeep Rubicon 4.5" short arm lift 1985 Jeep CJ7 30k in parts and still adding up |
11-25-2003, 01:08 AM | #2 |
Randy churchill
I also have two overdrive auto trannys.
A 700r4 out of an 82 blazer bellhousing has a ear broke off and needs rebuilt, $50 dollars. A 200r4 out of an 84 buick lasbre will bolt up to a chevy block, I pulled it out of my 67 2 years ago after installing a big block, will probably need rebuilt, $50 dollars. I also have a Van auto tilt column with a red hazard knob that I put in to look like a 67 column. It needs repainted. $50 dollars. I have small block motor towers out of my 67. $10 dollars for the set.
11-25-2003, 07:33 AM | #3 |
whats the casting number on the heads?
Scott |
11-25-2003, 11:41 AM | #4 |
Soulman67,
I am interested in the van tilt. Do you have any pics that you can post or e-mail? Also, can you post the numbers from the 200-4R that are stamped into the case on the pass. side (I think). Are you willing to ship or do you travel north on I-35? Thanks, Kent
'56 F-100 (w/all GM stuff) Lookin' for another parts chaser! '05 GMC crew cab |
11-25-2003, 08:05 PM | #5 |
Randy churchill
I will check the casting numbers off the heads after I clean them up and go get them out of my store room.
Kent my Digital Camera doesn't work on my new computer, I will get the numbers off the case sometime tommarow when I head down to where I got it stored. I might can work out a deal with my brother who lives near temple. So you wouldn't have to drive so far.
11-25-2003, 08:08 PM | #6 |
Randy churchill
Here is a pic of the tilt column when it was in my truck. It Doesn't have the intermediate shaft that conectes the column to the gearbox.
11-26-2003, 11:47 AM | #7 |
soulman67,
PM sent-picking up at Temple sounds like a good deal!
11-26-2003, 07:08 PM | #8 |
Beer Power!!!!!!!!!!
307 2gc carb
I am very interesed in the 307 2 barrell. Is it the original stock? If you can get a pic of the numbers I will buy it and the intake QUICK!
Rather be fishin' |
11-26-2003, 07:48 PM | #9 |
Watch out for your cornhole !
HEE HEE....he said perchjerker! That's funny
11-26-2003, 08:48 PM | #10 |
Randy churchill
I can't get a pic of the carb but it says 2 jet rodchester on top of it and the numbers on the bottum of the fuel bowl are 7031714.
It needs rebuilt, and is the manual choke model. The intake even still has the original oil filler tube with push on cap.
11-27-2003, 12:05 AM | #11 |
soulman67,
I'll take the column. PM sent. Let me know when you get the numbers off the tranny. Thanks!
