Old 02-01-2019, 08:35 AM   #1
Mains52
Ok Im going with coil spring fronts and coilover rears. What spring rates?
Stats: 52' Chevy 3100 with 5.3ls 4l80E trans. 3:23 chevy 10 bolt
My plan was to originally go with air ride. After much deliberation I decided to just go with Coil Springs in the front and Coilovers in the rear. I am building a daily driver so I am needing help with what spring rates I should go with.
Thanks for the help in advance.
Mains52 is offline   Reply With Quote
Old 02-01-2019, 08:51 AM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: Ok Im going with coil spring fronts and coilover rears. What spring rates?
I cant remember what the rear were but I have 450lb coilovers for the front.....LS3 and tr6060....the rears will also depend on if you have a rear fuel tank.but are less than the fronts......would be best to call whoever's your gonna use and let them recommend what you need..
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 02-01-2019, 12:16 PM   #3
whitedog76
If I remember correctly, you're using a standard MII setup.
There's been a number of discussions about it here and elsewhere. It seems the MII 4 cylinder are what most use for optimum comfort with an AD truck.
http://67-72chevytrucks.com/vboard/s...d.php?t=554035
http://67-72chevytrucks.com/vboard/s...d.php?t=438015
Some of it depends on where you're going to mount your tank, what engine, AC, etc... I see you're using an LS, which is lighter than a small block, but the 4L80 is pretty beefy.
I just recently finish the IFS install on my truck. Since I have a 3600 truck and I'm eventually going to add AC, I'm planning on using the 6 cylinder or even station wagon style springs for mine. I would rather have a slightly stiff ride than mushy handling.
Eaton Detroit has a good guide for MII springs. They have more selection than you know what to do with.
https://www.eatondetroitspring.com/o...-coil-springs/
As far as coilovers, can't help you there.
whitedog76 is offline   Reply With Quote
Old 02-01-2019, 01:28 PM   #4
b-mac
b-mac's Avatar
Tech at Speedway suggested 210# coilovers on the back. I have a 22 gallon, rear mounted tank. S10 chassis.
Haven't driven it yet...
b-mac is offline   Reply With Quote
Old 02-01-2019, 03:03 PM   #5
Mains52
Thanks Guys Ill be checking all of these links.
Old 02-04-2019, 08:37 PM   #6
BBPanel
I think you need to determine corner weights in order to minimize the trial and error method that will ensue.
BBPanel is offline   Reply With Quote
Old 02-04-2019, 08:53 PM   #7
MiraclePieCo
MiraclePieCo's Avatar
What's your front suspension - MII?
I used 350 lb fronts and 300 lb rears, but since mine is a panel truck that rear rating may be irrelevant for you.
I applaud your decision to go bagless. As a former "lay frame" guy myself, I decided on this build to eschew any unnecessary accessories or gimmicks and keep it all old school simple.
1951 Chevy Panel Truck
MiraclePieCo is offline   Reply With Quote
Old 02-06-2019, 10:23 AM   #8
Mains52
Thank You. That panel is slick!!
Old 02-08-2019, 12:13 AM   #9
mr48chev
mr48chev's Avatar
You might check with Rob at No Limit on them as they do coil overs on a lot of their chassis. http://nolimit.net/
My ongoing truck projects:
Old 02-08-2019, 08:34 AM   #10
Mains52
Thanks I'll look into them.
Old 02-19-2020, 12:42 PM   #11
Chris(NJ)
I know this thread is a year old, but I'll bump it anyway since some people may be looking for more answers/experiences. I have double adjustable rear coilovers that originally came w/ 175# springs. WAY too light. Ran it for about a year. They would compress so easily that I was even rubbing the driveshaft on big bumps! Swapped in 225# springs and it's been perfect. The ride is not harsh at all. Tank is mounted in the rear, original frame.
Chris(NJ) is offline   Reply With Quote
