Old 02-01-2019, 07:43 PM   #1
Tricky03
Tricky03's Avatar
Lowering my c1500 4/6...need front tire advice
I've got a '98 c1500 swb, 2wd with a 5.7. I'm going to install a Ride Tech, street grip 4/6 kit. My spring/summer/fall tires are the ones in the pictures and have the same size snow tires for winter (235/75r15).
Will these tires clear front and rear?
Thanks...
Tricky03 is offline   Reply With Quote
Old 02-02-2019, 01:22 AM   #2
oldschool18
oldschool18's Avatar
Re: Lowering my c1500 4/6...need front tire advice
I think they are the same size I have on my suburban and they work on mine. The front might be close but the back should tuck in. If you lower the front first and the fenders are sitting on the tires don’t worry till you get the back lowered, I usually lower the back first because of this problem when you drop that much. Just make sure you get correct shocks for the drop.
_________________________________
62 Impala
70 C-10 LWB
71 K-10 SWB
85 C-10 LWB==SOLD
01 2500 HD
Members Met......2003Silverado (Dave)
oldschool18 is offline   Reply With Quote
Old 02-02-2019, 02:06 AM   #3
Tricky03
Tricky03's Avatar
Thanks oldschool18,
That makes sense. I'll wait to see how it is once its sitting on the ground, lowered front and rear.
As for shocks, the kit comes with fully adjustable shocks front and rear with replicators for the rear. Great kit!
Old 02-02-2019, 02:23 AM   #4
oldschool18
Did it come with a c-notch?
62 Impala
70 C-10 LWB
71 K-10 SWB
85 C-10 LWB==SOLD
01 2500 HD
Old 02-02-2019, 02:29 AM   #5
Tricky03
Tricky03's Avatar
Yep...
Front:
Spindles, Coils, adj shocks
Rear:
Flip kit, C notch, shock re locator, adj shocks
Old 02-02-2019, 02:34 AM   #6
oldschool18
Have you ever done a kit like this before?
62 Impala
70 C-10 LWB
71 K-10 SWB
85 C-10 LWB==SOLD
01 2500 HD
Old 02-02-2019, 03:09 AM   #7
orngsikL
orngsikL's Avatar
they will fit, you will have to trim the "rain gutters" on the lower control arms to clear the wheels.
build thread - 1972 C/10 "Ethyl"
1974 C/10 " Paw Paw"
C/10 Club Louisiana
instagram -
@esso_c10
@projectpawpaw
orngsikL is offline   Reply With Quote
Old 02-02-2019, 03:15 AM   #8
EVRLET
EVRLET's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=775833
Start reading from post #12
Customization is what you want it to look like -- not what other people think it should look like
EVRLET is offline   Reply With Quote
Old 02-02-2019, 10:43 AM   #9
Tricky03
Tricky03's Avatar
Nice, this info is exactly what I needed. I've done similar kits like this before without having to do mods ('66c10, 71c10), none on this body style. I'm going to taper the rating guard like lip on the A arm instead of a blunt cut though. I do plan on tubular upper and lower arms this summer.
Here's my old '66 C10 and '03 S10 I did...
Old 02-02-2019, 10:48 AM   #10
Tricky03
Tricky03's Avatar
Here we go...
Old 02-02-2019, 12:20 PM   #11
oldschool18
I didn’t trim anything on my control arm, and I just wanted to ask cause that isn’t an afternoon project.
62 Impala
70 C-10 LWB
71 K-10 SWB
85 C-10 LWB==SOLD
01 2500 HD
Old 02-02-2019, 12:42 PM   #12
Tricky03
Tricky03's Avatar
We're planning on a solid day to do the suspension. One of the bed rail supports has to be notched to clear the 3rd member. Well trim and grind where necessary.
Old 02-02-2019, 03:34 PM   #13
SiCk_DiAbLo
SiCk_DiAbLo's Avatar
Thanks...
What was the price on that, I was thinking about doing one...
1993 Chevy Silverado.
1984 Chevy Z28.
1972 Chevy Custom 10.
1965 Custom 10..FOR SALE
SiCk_DiAbLo is offline   Reply With Quote
Old 02-02-2019, 05:00 PM   #14
Tricky03
Tricky03's Avatar
Fir the Ride Tech kit, its $1500. Yes, there are cheaper kits out there. I like how their kit is built specifically to provide much better performance and ride quality without sacrificing load capacity.
I plan on continuing to haul and tow with it so it was an easy decision for me to go with their kit. I'll probably end up fabbing some overload airbag brackets to add to the truck.
Old 02-03-2019, 12:21 AM   #15
likaroc13
Rollin' Old Skool
I’m running 235/70/15 up front on my Tahoe with 4/6 drop. The spare with a 235/75 will fit as well, but I think it would cause issues if the fender lip wasn’t trimmed (or rolled). I also have trimmed rain gutters on my lower control arms.
Phillip
My Build threads:
1966 Chevy C-10 "Black Betty"
Pics:
Previous Rides:
Old 02-03-2019, 11:24 AM   #16
Tricky03
Tricky03's Avatar
Thanks, likaroc13
I haven't trimmed or rolled my fenders yet. I know I'll have to down the road. I've got some smaller snow tires I bought for my '66 that I never used. I think they're 215/75r15's. I may just use them in the front for now.
I'm also guessing that I'll end up trimming the rain gutters off my LCA's as well.
Nice build BTW!
Old 02-03-2019, 07:08 PM   #17
likaroc13
Rollin' Old Skool
Thanks, likaroc13
Nice build BTW!
Thanks! I ran 225/70's up front on my old '93 C-1500 with a 5" drop up front. Doubt you'll have any issues with a 215/75. If you plan to run 15's, the LCA's will definitely need to be trimmed. Btw, I have a '66 as well.
Phillip
My Build threads:
Pics:
Previous Rides:
Old 02-03-2019, 08:59 PM   #18
Tricky03
Tricky03's Avatar
I am planning on running my stock 15's for now. I'll save up for 20's this summer...
I tried to pull up your '66 but my phone wouldn't work.
Old 02-06-2019, 10:23 AM   #19
SCOTI
SCOTI's Avatar
The tire sizes discussed are all fairly tall for a ~4" drop up front. They will fit... but @ those OD's there sure is the possibility of buzzing. The taller the combo, the more it's going to happen.
Same truck. Same drop. It's 'based' on a 4/6 drop (2" spindles; 1-coil removed from OE 6cyl coils; flip kit + shackles). It's possibly a tad lower; definitely so in the rear. With the 15" Ralleys, it ran 215/70-15 BFG's (26.8") & did not buzz the wells. The new combo recently installed is closer to the sizes you guys have discussed & it constantly buzzes (225/60-17's @ 27.6").
Spring rate up front will come into play. If running a taller combo, I would def ensure the spring rate is upped to help prevent the annoying buzzing.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-06-2019, 12:27 PM   #20
Tricky03
Tricky03's Avatar
Thanks for your info, SCOTI. The 215/75r15 I'm wanting to run is right at the same height as your 225/60r17. I think im going to go with a smaller one for sure. I'm not wanting to tear anything up, tire or fender...
Old 02-06-2019, 12:45 PM   #21
SCOTI
SCOTI's Avatar
My buddy who now owns the truck swapped the larger dia 17's on there for an updated but old-school look. I cringed @ the tire height choice & mentioned concern. He confirmed my concerns & said it buzzes more than he cares for but that "it's fine on smooth roads though".
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-06-2019, 05:18 PM   #22
Tricky03
Tricky03's Avatar
Having them rub would get really annoying. I plan on continuing to use my truck to haul and tow so having tires that dont rub is crutial.
Old 02-06-2019, 11:10 PM   #23
likaroc13
Rollin' Old Skool
Everyone's experiences may be different, so I can only speak from mine personally; but I never had any "buzzing" issues with my '93 that had an approximately 5" (possibly lower) front drop with Western Chassis spindles & springs. The springs were actually trimmed just a bit because they sat more like a 4" drop. I ran a 225/70 up front with factory 15x7" mid-90's Caprice steel wheels. It had Doetsch-Tech shocks.
For the rear, I would definitely consider helper air bags if you plan to tow/haul. On the '93, I had a mini-notch that came with the drop kit. It had a flip kit with 2" drop shackle, so 8" total. I never hauled/towed anything, but it would bottom out on decent sized dips/bumps. It would've helped if I had trimmed the bed crossmember just above the "pumpkin." I ran a 255/60 rear tire on the same 15x7" Caprice steelies. Not sure if there are any differences between fleet & stepside bed pertaining to clearances.
19 by likaroc13, on Flickr
My '97 Tahoe has a 4" drop up front with spindles/springs. It has a 235/70 on 15x7" Wheel Vintiques smoothie wheels with custom 4.5" backspacing. Shocks are Belltech Street Performance. I've never had any "buzzing" issues with these either, & I've been over more rough roads in this than I ever took with my '93.
IMG_3595 by likaroc13, on Flickr
Phillip
My Build threads:
Pics:
Previous Rides:
Old 02-07-2019, 12:51 AM   #24
Tricky03
Tricky03's Avatar
Hello likaroc13, nice rigs!
I appreciate your detailed info, very helpful!
I'll take as much info I can from all of you, thanks.
I'm guessing that the buzzing noise is the tire tread, scraping the inner fender plastic, making a buzzing sound...I've heard it myself when I did the 5/7 on an '03 S10. Easy fix though...tire was hitting the plastic screw fastener over bumps and dips in the road. Removed the fastener, no more noise.
I've had my fair share of dropped trucks and know all are different. I've never lowered one of these before. I went ahead and put my 215/75r15 tires on the front so I should be just fine, we'll find out.
I'm going to notch the brace under the bed to clear the pumpkin. I'll also be putting overload/helper bags on the back to haul and tow. At 4/6, I should have more than plenty clearance around everything. If I make it a 5/7, I should still be ok.
FYI, this is exactly why I joined this forum. Like minded people sharing their real world experience. No BS...is so nice!
Old 02-09-2019, 11:51 PM   #25
Tricky03
Tricky03's Avatar
After a long day and "suprise", 4" of snow...my buddy Eric and I lowered it. The RideTech kit is awesome. The quality and fit are great. Very well engineered too. I put the 215/75r15's on. We'll see if they rub or not.?.?.? I have to get an alignment done ASAP.
