02-02-2019, 11:52 PM | #1 |
Tail Light Bezel Install Alternative
Has anyone installed the Tail light bezel with 3m Double sided tape? Truck is at paint jail and would like to fill any holes that are not necessary. I will be doing this method for my lower molding on the side of truck.
02-03-2019, 12:20 AM | #2 |
Re: Tail Light Bezel Install Alternative
A better method is windshield eurethane. Tape it on until it dries.
100% non paintable silicone works too. Tape will not work for the taillight bezels, not much behind to attach it |
02-03-2019, 12:55 PM | #3 |
I will second the windshield adhesive method.
My 68 was painted back in 91 and I recently removed the 10 emblems from the front fenders. They were put on with urethane back then, when I pulled them this last summer the top 2 layers of paint came with em. Just a few dabs should do it, that stuff is strong.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
02-04-2019, 01:56 PM | #4 |
Or, just leave them off...cleaner look.
02-04-2019, 08:23 PM | #5 |
02-05-2019, 07:09 AM | #6 |
I'm a fan of the cleaner look. Consider a roll pan for that look otherwise put on the chrome to compliment the bumper
02-05-2019, 02:21 PM | #7 |
The stock installation requires the use of two oval head sheet metal screws along the tailgate side of the bezels, in addition to the clips that go around the outside perimeter. I just used the screws without the clips. Tweaked the bezel just a tad so that it snugs down around the outer perimeter when I tighten the two screws. Its not going anywhere.
02-05-2019, 03:58 PM | #8 |
On mine I went for these Fesler Built tail lights as an alternative
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
02-05-2019, 04:30 PM | #10 |
I'd love to hear your impressions of the side marker lights once installed - curious how flush or close to flush they end up! Thank you.
02-15-2021, 05:55 PM | #12 |
Were did you guys get the fesler lens, I can not find them.
02-15-2021, 11:36 PM | #13 |
Old member
I had all the trim on my 71 welded up. Over 50 holes gone. I love the clean look and or the naked look!
One of the best mods I ever done to my truck.
02-16-2021, 09:52 AM | #14 | |
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
02-16-2021, 05:52 PM | #15 |
As I asked were can you even get them, it does not look like they are made anymore.
02-16-2021, 07:22 PM | #16 | |
02-16-2021, 09:45 PM | #17 |
Old member
That link says they are Not Available.
02-16-2021, 10:28 PM | #18 |
I guess it does. Maybe they don’t sell them anymore. I checked shopfesler.com and they were not listed at all.
02-17-2021, 05:39 PM | #19 |
Not sure if the one set he had is left but you might check here.
http://67-72chevytrucks.com/vboard/s...d.php?t=795793 They are very nice but a bit rich for my pocket book. Dave
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
02-17-2021, 09:10 PM | #20 |
Digi-tails had them. Might be worth a two minute phone call to see if they can get/make more. http://digi-tails.com/1967-72-gm-tru...lights-reverse
02-17-2021, 09:11 PM | #21 |
I'm sporting the naked look. Front, back, sides....all naked
02-19-2021, 12:51 AM | #22 |
Good luck getting Digi-tails to answer OR call you back...
I ended up getting a set of Marquez Designs from Matt's Classic Bowties. Even though I am so far away from needing them, I jumped at the chance to get some as they are so hard to find. Hit them up, they may have a set left. https://digi-tails.com/marquez-desig...ht-lenses-back |
