Old 02-03-2019, 12:08 AM   #1
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
Gen5 pcv hookup question
Not many have done l83 swaps, but for the ones who have how are you connecting the 2 ports on the valve covers?
Just 2 filters on em?
I was thinking connecting them together and run them to the intake tube somehow.. or could you connect them to the unused purge valve port? Been looking online and again, no answers..
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 02-03-2019, 12:13 AM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: Gen5 pcv hookup question
how are they run in the original truck?...pics might help
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 02-03-2019, 01:43 AM   #3
kazoocruiser
I think if you just run filters on them you are going to hate the underhood smell every time you decelerate and crankcase vapor is highest.
It's better if you can tee them together and port it to manifold vacuum, which is highest during deceleration, and will help purge the sump.
kazoocruiser is offline   Reply With Quote
Old 02-03-2019, 11:22 AM   #4
87chevy.com
Stock runs both hoses to the intake tube.
Aftermarket intakes has a bung welded to them, no baffle from the pictures I've see.
I'm gonna play around with some scrap 1/2 hose and run it to the purge valve port... see how that works if not just weld a bung to the intake tube and run the hose there
Clint
Old 02-03-2019, 05:22 PM   #5
mongocanfly
Post Whore
I'm pretty sure on the older setup the fresh air side (passenger) is metered... the otherside (driver) is not...
Jonathon (dayj1) will know...he explained it to me but I cant remember the exact....something about the engine thinking it has a vacuum leak...
So I'm thinking your fresh air side should be before the throttle and the other side after the throttle...
If it was originally in the intake tube I'd put it back there in your new setup..
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 02-03-2019, 08:11 PM   #6
87chevy.com
Hope he chimes in.. they both go to the massive stock air intake tube, aftermarket look like it's just bungs so neither setup could measure the air flow... or that I can see how anyway
Dont pay attention to the fan relay, its temporarily.
Not bad for Mickey moused together with scrap stuff, but no dice. Way to much vacuum on that port without a restriction, I could barley remove the oil fill cap. Too much vacuum like that will damage seals .. I might grab a 3/8 bolt and chuck it up in a drill and cut off the smooth part and start with a 1/8 hole and make a restrictor, but may just order some bongs online. This looks way to good to work..
Clint
Old 02-03-2019, 11:23 PM   #7
sprint_9
sprint_9's Avatar
The two ports in the valve cover on those engines are fresh air in, dont connect to the purge port which is under vacuum. You have no ventilation occurring or very little because the entire pcv system is under vacuum.
Those two ports go to your intake tube, like stock, but it doesnt matter if you tee them together like you have them, as long as they arent under vacuum, so put them before the throttle blade. The vacuum side of the pcv system comes out by the front of the cam and runs up to the middle of the drivers side of the intake.
sprint_9 is offline   Reply With Quote
Old 02-04-2019, 12:12 AM   #8
87chevy.com
Gotcha thanks, found some aluminum barbs on ebay, gonna give them a try
Clint
