Old 02-03-2019, 11:10 PM   #1
jkk
jkk's Avatar
Spray dye interior pieces dried cloudy
Hey guys
I sprayed some interior pieces burgundy and some of them when they dried were cloudy and dull???
Any ideas what happened should I add a few more coats?
jkk is offline   Reply With Quote
Old 02-03-2019, 11:18 PM   #2
rideair
Re: Spray dye interior pieces dried cloudy
Had the same problem happen, mine was the humidity level in the air.
Waited until the next day with less humidity, worked out fine.
Be sure to go by what the manufacture says to do.
Not saying that's your problem, but could be.
Good Luck,
rideair is offline   Reply With Quote
Old 02-03-2019, 11:27 PM   #3
jkk
jkk's Avatar
Good Luck,
Yeah it was real humid today will try again
Old 02-04-2019, 05:37 AM   #4
TKCR
TKCR's Avatar
I have had this too at times, but they go away as more coats are added. Make sure you keep the can shook up good during all the coats of applications. Maybe it was the humidity, it always takes me a few days to get everything done.
If your still not satisfied with the look, you can always add a light coat of satin clear.
Old 02-04-2019, 11:54 AM   #5
SCOTI
SCOTI's Avatar
Humidity is #1 on the list when you get a cloudy finish using rattle-can type coatings.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-04-2019, 05:07 PM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
Very true. You cant fight humiidty when it comes to vinyl dye. Try a small space heater to dry the air near your work zone.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
